Go Back   CNCzone.com-The Largest Machinist Community on the net! > MetalWorking Machines > Shopmaster/Shoptask
Shopmaster/Shoptask Discuss Shopmaster/Shoptask machinery here!
Old 11-27-2007, 08:15 PM
sstec is on a distinguished road
ElDorado upgrades
Guy's
Long time Lurker.............
I've read just about every post about ST here and else where on the web.
I bought a just slightly used ST Eldorado last year on eBay for next to nothing.
DRO and tooling, no ball screw or CNC.....
Since then I have turned a few things and made chips, trying to teach myself and reading everything I can when I can.
I have ordered Dan's CNC kit, should be here by the end of the week.
So here is the question for those of you who have been there, done that.
Scott
Bloy
dahui
rainman
And others
Of all the things you have done to make your ST better, what would you do different if you had it to do over again?
Most went to 1.5 HP VFD's is that enough? 2 HP?
Stuff like that............
Thanks for all your shared input you have posted for the rest of us to learn from.
sstec
Old 11-29-2007, 01:49 PM
mixdenny is on a distinguished road
Do you have a Quadralift installed? That is a huge improvement in the milling operation. At any rate, they are no longer available as I got the last one from the factory several years ago. Hopefully you do have the Quadralift, so the next thing to add is the fifth arm to make it into a bridgemill. This is an incredible stiffening effect and makes milling steel a pleasure. It takes a bit of effort to make one and set it up accurately, but you will love it. Then add a power drive to the Quadralift and an auto belt tensioner to the mill motor. These are both things that just make it so much nicer when you are milling. I find that I have to move the head up and down quite a bit when going from drills to end mill, etc, and the powered lift is great. I have a web page that shows my homemade bridegmill, powered lift and a few other mods at:
http://home.wowway.com/~dthompson4389/Shoptask.html
Enclosure on a Eldorado Bridge mill Rainman229 Shopmaster/Shoptask 1 03-08-2008 11:59 AM
CNC Kit and Ball Screw set Install on Eldorado Bridgemill gfull60 Shopmaster/Shoptask 7 12-26-2007 10:38 PM
Eldorado Motor Replacement giantcake Shopmaster/Shoptask 2 05-29-2007 06:24 PM
optimal setting for eldorado cnc setup. Rainman229 Shopmaster/Shoptask 3 03-11-2007 01:40 AM
Specs for cnc small parts - Shoptask Eldorado pfarber Shopmaster/Shoptask 2 12-09-2006 11:13 AM
