Go Back   CNCzone.com-The Largest Machinist Community on the net! > MetalWorking Machines > Shopmaster/Shoptask
Shopmaster/Shoptask Discuss Shopmaster/Shoptask machinery here!
  #13   Ban this user!
Old 01-09-2010, 09:55 AM
sharpshooter90 is on a distinguished road
Originally Posted by Lemo View Post
No, that is not alright on ballscrews. Acme or comparable yes, and that would go along with the cost for them... but for ball screws that is disappointing. I probably end up buying a mill and retrofit it...
Lemo
Shoptask uses the NOOK brand rolled thread ball screws which are advertised by NOOK as having 0.003-0.005" lash. If the lash is more than that it would most likely be in the adjustment of the ball thrust bearings or a loose mounting bracket. Loose pulleys on the stepper motor or lead screw will also show as lash. My machine is right within the advertised range, and with backlash compensation properly set in the software, I get excellent repeatabililty. If you plan to do your own conversion, the rolled thread screws can be had for about 125.00 per foot including the nuts and shipping. You can add another 100.00 per axis and get the double nut setup for less lash. The next step up is ground thread screws, but they will be more than the machine itself. Be realistic in your plans- if you want better than 0.001" general repeatability, plan to go to a much larger and more expensive machine.
  #14   Ban this user!
Old 01-14-2010, 01:37 AM
digibit is on a distinguished road
Life with a Shoptask Bridgemill
While not the current "Patriot" model, this site has compiled what appears to be honest opinion, experience and a decent selection of photos as well as info.
http://the-alchemist.com/
I put Carriage stops / E-stops on the x&y Shoptask 1739 Gunmaster....I was bored lol spunky1974 Shopmaster/Shoptask 0 06-30-2007 04:13 PM
Right VMC for the task hardrocker General Metal Working Machines 0 04-05-2007 09:55 PM
Worth anything? krebsatm02 DIY-CNC Router Table Machines 6 04-25-2005 10:49 PM
Daunting task mikie DIY-CNC Router Table Machines 7 08-06-2003 06:28 PM
Worth it CNCadmin Benchtop Machines 3 04-01-2003 11:21 PM
