Results 1 to 6 of 6
Thread: Laptops Running Mach3?
    Aug 2007
    Is anyone out there running Mach3 on their TriPower with a LAPTOP? If so, I'd be interested in knowing which one; make, model, O/S, etc.
    Thanks for your input.
    Fred
    Feb 2006
    Not on aTri-Power but on my homemade machine. No problems except for having to stop the screensaver and powerdown aspects. I quit using it and got an old desktop just to keep the dust out of the laptop. Its a Toshiba A-75.
    Dave
    In the words of the Toolman--If you didn't make it yourself, it's not really yours!
    Remember- done beats perfect every time!!
    Jan 2006
    I briefly ran Mach 3 on an old (1999) dedicated Dell Latitude CPi-R. This is a 400 Mhz machine w/256M, and a very clean install of XP. I had no trouble generating 25kHz, but eventually switched to an old desktop to get the 45kHz pulse rate. My CNC is a DIY benchtop model.
    Steve
    Registered dahui's Avatar
    Dec 2005
    Do you already have a laptop or are you looking to buy one? I wouldn't think it would take that much computing power. Of course more is always better.
    Jan 2006
    I *thought* I was generating 25,000 pulses/second on that machine, but was probably actually operating much lower. Lately I have found that my 800 Mhz desktop is cpu bound at about 1/2 that (13K pulses). This leads to all kinds of poor performance, especially motor stalling. While Mach will run on slower machines, don't expect to push your feed rates very hard.
    Steve
    Dec 2006
    I'm running a 5 year old Compaq 2Ghz laptop running WinXP at 45Khz with no problems at all. Homemade router with gecko's.
    Hope this helps.
    Brian
    1. Running Mach3 for laser cutting questions
      By CNCadmin in forum Mach Plasma / Laser
      Last Post: 09-14-2007, 11:34 PM
    2. mach3 running xylotex 3axis weird problem
      By Claude Boudreau in forum Xylotex
      Last Post: 07-18-2007, 06:24 PM
    3. Anyone running Mach3 with a DynaCNC table top?
      By CrashMasterKev in forum Machines running Mach Software
      Last Post: 11-21-2006, 09:36 PM
    4. Mach3 running my mill drill using the G203 Vampire drivers
      By Dan Mauch in forum Benchtop Machines
      Last Post: 11-15-2006, 02:15 PM
    5. Mach3 running the new G203 Vampire drivers
      By Dan Mauch in forum Gecko Drives
      Last Post: 11-15-2006, 02:00 PM
