| Shopmaster/Shoptask Discuss Shopmaster/Shoptask machinery here! |
Basicly Trying to find what the best motor settings for mach 2 or 3. The cnc motors and controler are the ones that are from shoptask. ANy help would be great.
__________________ http://www.rainman229.com |
Here are the settings from my Shoptask Tri-Power with acme screws and the shoptask CNC package. The step were determined via DRO. motor config (MILL) step pins / direction pins x Axis 2 / 3 steps 40000 velocity 24.366 accel 2 y Axis 4 / 5 steps 40000 velocity 22.41 accel 1 z Axis 6 / 7 steps 63899 velocity 3.72 accel 0.823956 ---------------------------------------------------- motor config (LATHE) step pins / direction pins x Axis 4 / 5 steps 40000 velocity 24.366 accel 2 y Axis Not used z Axis 2 / 3 steps 63899 velocity 23.286 accel 2 Yours should be close to this. |
| what are you using steppers or servos?? To ball park steppers: How many steps per rev the moter has (usually 1 step = 1.8 deg), X any micro step settins, x your drive ratio, x your tpi (if using imperial screws). will give you how many steps it takes to move 1 inch. Servos: Encouder count per rev. x (line count if you have one), x drive ratio x tpi. then tell it to move 1 inch, measure what it really moved, devide what you told it to move by what it moved. take that number and multiply to your current steps/unit. (BTW: move back to 0 befor you ajust your steps per inch). Repeat until you moving 1 inch each time. Then go back to 0, and tell it to move 6 inches (on X or Y), measure what it moved and divide that into 6, and it will give you a longer averaging error over travel. If you want to really get it down. then, command a full length axis move, measure and repeat above. Scott |
| sorry guys been a little too busy to check in on this. I'm running steppers right now x and y are at 8000 seems to be right on the money. Z is in the 5000 somewhere My biggest problem is not so much the steppers them selves. It's more the max speed. i guess i would need to toy with that on my own. trying to figure out the max depth i could cut with a desent speed. My max speed at the moment is at .900 sec and i think it should be able to handle .100 pass with no problem. Note I mostly work with 6061 alum and some plastics.
| Specs for cnc small parts - Shoptask Eldorado | pfarber | Shopmaster/Shoptask | 2 | 12-09-2006 12:13 PM |
| Setting z | bbergami | G-Code Programing | 4 | 10-01-2006 09:21 AM |
| Finding optimal components for servo drive | Xerxes | General Electronics Discussion | 20 | 08-22-2006 06:29 AM |
| Setting up VM5 | dneisler | Visual Mill | 6 | 03-12-2006 10:50 AM |
| What is your opinion on optimal table height? | Madclicker | DIY-CNC Router Table Machines | 6 | 12-03-2005 11:23 AM |
