| Shopmaster/Shoptask Discuss Shopmaster/Shoptask machinery here! |
| Removal of the drill press depth stop threaded rod Bloy, I see you have removed the threaded rod that was the drill press depth stop. How did you do this? I can't see how the rod is attached to the arm. I have decided I should move my Z-axis DRO sensor, and I intend on doing a similar mount to yours, but need to remove the rod. |
| Hi there... Gee ...I missed this question.... The threaded rod is held in place by a taper pin that should drive out from right to left as it is on the machine. Then, the threaded shaft can be driven up and out as it is turned to 10mm on the inserted end(no threads). Be carefull to provide backup if doing this on the machine... The parts are pretty tight on mine. Actually, to get the rod out after removing the pin, I grabbed it with a visegrip and twisted it up....didn't want to knock anything out of kilter. Last edited by Bloy2004; 02-26-2004 at 01:20 PM. |
| Thanks. I chiseled my way through the 1/8" of paint and apparently bondo on that portion of the machine, and found the pin. Once I get through my next production run tomorrow, I'll start on the next modification. Last edited by devinchi; 02-26-2004 at 02:45 PM. |
| Hah! This part I stripped when rebuilding the machine and that is when I discovered the pin....otherwise I had initially been under the thought that the rod was screwed into the bracket... |
| Home made threaded rod | andy_ck87028 | Mechanical Calculations/Engineering Design | 10 | 07-19-2005 09:26 PM |
| Central Machinery Drill Press | JavaDog | General Metal Working Machines | 10 | 05-25-2005 11:14 AM |
| Drill Press or Mill/Drill? | cbcnc | Benchtop Machines | 2 | 03-05-2005 06:03 PM |
| Drilling a perpendicular hole in drill rod material | ngr1 | General Metalwork Discussion | 12 | 12-04-2004 10:16 AM |
| Thomson vs. ground drill rod | TommyB | DIY-CNC Router Table Machines | 10 | 03-21-2004 11:08 AM |
