Go Back   CNCzone.com-The Largest Machinist Community on the net! > MetalWorking Machines > Shopmaster/Shoptask
Shopmaster/Shoptask Discuss Shopmaster/Shoptask machinery here!
Old 10-15-2006, 06:28 PM
S Lovette is on a distinguished road
How do I adjust the backlash
So this is where you all went. The "official" forum is dead!
Can someone write the procedure to adjust the x axis backlash with the split nuts? Shopmaster hasn't started shipping manuals with the Tri-Power yet. My backlash is so awful I can't even participate in the rocking table discussion.
I have acme screws.
Spencer
Old 10-19-2006, 01:07 AM
bicycleboy is on a distinguished road
Spencer,
I too would like to know how to adjust them. I wonder if the Eldorado has similar double acme nuts? I will ask John at Shoptask if nobody posts in the next few days.
Old 10-19-2006, 10:10 AM
The Eldorado nut is the same.
JT Says:
The nuts have a spring between them- if you loosen the clamp bolts, the
spring will push the nuts apart and make contact wwith the leading and
trailing edges of the nut- sometimes you must move the table a bit back and forth by hand to get them to seat.
Spencer
Old 03-15-2010, 02:57 PM
instructor37 is on a distinguished road
JT Says:
Spencer
Our patriots have double nuts but no spring. Instead they have one of the nuts with a flange and 2 small set screws. When you turn the set screws it moves the flanged nut away from the other nut, putting contact on both sides of the threads and reducing the lash. Be careful though- its easy to go too far and then you cannot turn the screw at all.
