Go Back   CNCzone.com-The Largest Machinist Community on the net! > MetalWorking Machines > Shopmaster/Shoptask
Shopmaster/Shoptask Discuss Shopmaster/Shoptask machinery here!
Old 01-08-2004, 12:51 PM
devinchi is on a distinguished road
toolpost height issue
Well I started using the lathe on my bridgemill today only to realize that the toolholder is too high. The included cutting tools when put in the quick change toolholder sit .08" above the center of the lathe. I can't see any way to adjust the tool down, as the toolholder is bottomed out, so does this mean I have to shim the lathe head UP?!?!!?
Old 01-08-2004, 01:43 PM
HuFlungDung's Avatar
Moderator
Hi Devinchi,
No do not move the lathe headstock, ever.
They have supplied you with the incorrect size tools or the toolpost has not been fitted to that machine.
What size are the shanks of the tools now?
Old 01-08-2004, 01:58 PM
They are 1/2"
Old 01-08-2004, 03:27 PM
Moderator
Your simplest solution would be to use 3/8" shank tools. I'm assuming these are brazed carbide or else solid high speed steel square bits? The other choice would be to mill a bit off the bottom of your toolblocks so that they can sit down a little bit further, if that is the area of obstruction.
Beware, the blocks are likely hardened, so go slow, with a carbide endmill.
Old 01-08-2004, 04:13 PM
Bloy2004's Avatar
Fumbling Machinist
Bloy2004 is on a distinguished road
Devinchi
If my shoptask tool holder is the same as yours then you have a main tool post with four vertical channels, one on each face of the post. The holder rides up and down in that channel and has a lip on top protruding over the post through which the adjustment screw is located.
What HuFlungDung suggests makes good sense....to take some of the bottom of that lip off.
Also, you could mill down a portion of the post on each face where that lip rests when the tool holder is all the way down. This may be easier as the post is already mounted and secure.
My QC holders are so very close to being bottomed out....but not quite.
Tool height "touch off" tool unusable DHK DeskCNC Controller Board 6 05-06-2006 01:54 PM
text height 47MLB Mach Software (ArtSoft software) 1 03-16-2005 06:34 PM
How important is torch height control? mm0015 CNC Plasma and Waterjet Machines 4 08-06-2004 12:19 PM
Z Axis Height question? redbaron DIY-CNC Router Table Machines 4 02-06-2004 09:34 AM
Tool Height Offsets JamesBond Machine Problems, Solutions , Wireless DNC, serial port 6 06-01-2003 03:01 PM
