Go Back   CNCzone.com-The Largest Machinist Community on the net! > MetalWorking Machines > Shopmaster/Shoptask
Shopmaster/Shoptask Discuss Shopmaster/Shoptask machinery here!
Old 05-18-2006, 09:40 AM
bherr is on a distinguished road
Thumbs down Mach III error message-Help
I recently purchased the new tri-Power CNC, which comes with the MACH III software. I'm using BobCad/CAM software to produce drawings and generate the G-code, no problem there. the Tri-power uses the parallel port on the computer to control the CNC processors on the machine and BobCad uses the RS-232. In order to get the machine running you have to save the bobCad file and then import it into the MACH III, no problem there. I generated a small program to do some milling and then loaded into Mach III and received the following message, "F word missing with inverse time arc move on line number #5". I contacted bobCad support and they had me send the program to them and they got it to run with no problems. I'm waiting for Camtronics in seattle to open so that I can call them, but though maybe someone could help in the mean time.
Ben
Old 05-18-2006, 10:05 AM
Gold Member
JFettig is on a distinguished road
Can you post your code? Its likely the feedrate isnt right somewhere. and why are you running inverse time?
Jon
CNC Mini Lathe Plans and Rotary Table kits:
http://jfettigmachines.com
Old 05-18-2006, 11:24 AM
ger21's Avatar
Are you using the Mach3 post from BobCAD's site?
Old 05-18-2006, 02:08 PM
Error message
That's what the bobCad generated gor the G-code. I'm new to machining so no familar with inverse. I can save the bobCad file to the Mach III and then load it into Mach III, then the error message shows up down at the bottom.
Old 05-18-2006, 03:28 PM
ger21's Avatar
Post the code here and we'll have a look.
Old 05-19-2006, 08:11 AM
thanks guys, but I called Camtronics and they had me do some config stuff and that fixed the problem.
Ben
