Page 1 of 2 12 LastLast
Results 1 to 12 of 20
Thread: ShopTask under glass...Plexiglas
    Registered HogDog's Avatar
    Aug 2004
    Got tired of wearing coolant and chips around, so I built an enclosure.
    Its 60"x36"x48" tall.
    Attached Thumbnails Attached Thumbnails ShopTask under glass...Plexiglas-less_doors.jpg   ShopTask under glass...Plexiglas-complete.jpg   ShopTask under glass...Plexiglas-left_back.jpg   ShopTask under glass...Plexiglas-back_right.jpg
    ShopTask under glass...Plexiglas-doors_light.jpg   ShopTask under glass...Plexiglas-top.jpg
    Dec 2003
    Very very nice. I only wish I could do the same for my 9' tall Bridgeport.
    Proud owner of a Series II Bridgeport.
    Aug 2004
    Talking
    Quote Originally Posted by Cold Fusion
    You could...first start with a shower stall...j/k LOL
    Aug 2004
    I still need to coolant proof a few things...move the lathe, X and Y axis motors 180 degrees about. feed thru's for wires and hoses. The list just gets longer and longer.
    Dec 2003
    How thick was the Plexi that you used?
    Aug 2004
    .085" wall and doors.
    .110" roof
    Doors are kinda floppy.
    110 all around would be nice.
    Registered JavaDog's Avatar
    Mar 2004
    Quote Originally Posted by HogDog
    Ya know, that isn't all that bad of an idea really...
    Check Out My Build-Log: http://www.cnczone.com/forums/showthread.php?t=6452
    Banned
    Nov 2005
    Thailand
    How about noise.....
    .110" roof
    Does your enclosure reduce noise to any extent?
    Aug 2004
    Quote Originally Posted by geoff p
    It does to an extent. The high frequency noise is alot less, but low freqs will always get by without futher dampening.
    I have the right side adjecent to an inside wall...lots of noise.
    Attached Thumbnails Attached Thumbnails ShopTask under glass...Plexiglas-100_1016a.jpg
    Aug 2004
    Lower shot of enclosure and leak test.
    It sits in a pan on plywood and a metal cabinet.
    Attached Thumbnails Attached Thumbnails ShopTask under glass...Plexiglas-100_1012a.jpg   ShopTask under glass...Plexiglas-100_0892a.jpg
    Aug 2004
    Holes
    punchin' out some holes and stayn' dry.
    Coolant is Rustlick 50/50 10:1
    Attached Thumbnails Attached Thumbnails ShopTask under glass...Plexiglas-holes.jpg
    Aug 2004
  • Page 1 of 2 12 LastLast
