| Shopmaster/Shoptask Discuss Shopmaster/Shoptask machinery here! |
I have a 1999 1720 XNTC Gold that is not CNCed. I remembered that there used to be a conversion to bolt the tail stock to the table to be able to use the power feed to move the tail stock. I think it was some sort of shoulder bolt. Anybody know what size bolt was used? Pictures? Thanks Rick |
| The bolt has a 5/16" shaft and thread. It is long enough to pass through the tailstock base and stick out 1 1/2". The part that sticks out the front is 9/16" diameter, 1 1/8" long with a 3/8" length of 5/16" thread cut on the end. The back end has a large (1 1/8") hex knob held on by a set screw. You remove the knob and install the bolt through the tail stock, then relock the knob. It remains in the tailstock. The 1 1/8" long portion is a spacer to hold the tailstock back far enough so the cross feed lock lever can be operated. Dennis |
| Thanks for the information. I spent some time looking at the tail stock and I was thinking of ordering a 4” long 5/16 shoulder bolt with a ¼ x 20 threaded end. I was just going to make a spacer out of some ¾ aluminum round stock to get the clearance to allow for the table lock. I would drill and tap the cross slide for the ¼ x 20 thread. Thread it in when I need it and remove the pieces when I don’t. Thanks Again Rick |
| HIT-18S, need help with tailstock | BNR_RANDY | Hyundai Kia machine | 3 | 01-14-2011 02:39 PM |
| TL-1 Turret/tailstock question | hercules | Haas Lathes | 9 | 02-13-2009 02:33 PM |
| Tailstock Alignment Question | tigermothracing | General Metalwork Discussion | 1 | 09-04-2008 09:49 PM |
| Haas SL-30 Tailstock question | chrisryn | Haas Mills | 1 | 05-07-2008 01:44 PM |
| TL-2 tailstock | rbest27 | Haas Mills | 2 | 11-10-2006 05:20 PM |
