Originally Posted by
Gulbrandr
Ok, I get z axis being the spindle center line in both mill and lathe. But say I've been running mach3 mill wizards [which run fine] then switch to mach3 lathe, what must I change to switch z axis from mill to lathe? Of course the spindle control switch changes the motors but not the steppers. The mill stepper operates in mach lathe. I tried changing active plane of movement in general config but it keeps changing back even with restart. I hope this makes sense cause I'm certainly confused.
