07-27-2011, 09:37 AM
Originally Posted by tgorsuch I have a 1720 gold and the motor on the lathe went out today. Any thoughts on where to get a new motor. Would like to find something that is variable speed.
Tgorsuch |
Have you talked with JT at Shopmaster? On those motors, the most common failure is the start capacitor, especially on the lathe where you might be doing a lot of repeated start-stops for measuring your part. Changing the capacitor is easy and cheap.
I know the new Patriot machines are all equipped with 3 phase variable frequency drives, so there may be an upgrade available for your machine. |
