Go Back   CNCzone.com-The Largest Machinist Community on the net! > MetalWorking Machines > Shopmaster/Shoptask
Shopmaster/Shoptask Discuss Shopmaster/Shoptask machinery here!
Old 02-06-2011, 11:18 AM
LX Kid's Avatar
LX Kid is on a distinguished road
ShopTask 17-20 XMTC Parts ID Help (W/PICS)
I have a 1993 Shoptask 17-20 XMTC that had been converted to CNC before I bought it. It came with a box of parts and am trying to decide what they might be for. The parts on the right are probably for the lead screw that had been removed when it was converted. The parts on the left are for "what" I have no idea. Can someone tell me what parts I might be missing should I want to remove the CNC mod and what the other parts might be for? Several pics below for your opinions. Thanks
THE ONLY PART REMOVED WAS THE LEAD SCREW TO FACILITATE PAINTING. APPEARS THERE IS NO FORWARD/REVERSE MECHANISM TO CONTROL THE LEAD SCREW DIRECTION. HMMMMM!
Old 02-07-2011, 07:34 AM
instructor37 is on a distinguished road
LX,
It appears that some of the parts have been modified and some fabricated- If someone can help you, it would be easier if you re-shoot your pictures and label each part A, B, C etc.
Then someone can say A fits on B and so on.
Old 02-07-2011, 07:47 AM
LX Kid's Avatar
Thanks "Instructor37" for the suggestion. I'll edit my photo's in a short while. Good idea and thanks!
Old 02-07-2011, 08:06 AM
LX Kid's Avatar
See the edited pics below for ID reference numbers. Thanks
Old 02-10-2011, 03:53 PM
LX Kid's Avatar
Found some more parts, that I think go to the 3-In-One, and can't say what they are for either.
Old 02-11-2011, 09:53 AM
smallblock is on a distinguished road
D-1,2,3 were all temporary supports for the machine when shipped in the crate- toss them
C1-6 don't look like anything for the machine-
Old 02-11-2011, 10:17 AM
LX Kid's Avatar
Thanks SmallBlok. Yesterday I was able to track down the original owner who made the accessory parts for this machine. I sent him this link and asked if he will help ID some of the parts he made. Just have to wait until he gets time to reply. Thanks
Old 02-11-2011, 10:26 AM
You've got a home-made forward shifter mechanism-
Start at the lead screw end and work your way up.
1. On the lead screw you should have a double unit- part of it is a tooth belt pulley for the cnc belt and the other part is a coarse tooth gear.
2.Shaft A3 should fit into a hole on the casting and is held with a set screw.
3. Part B2 with the bushing should fit over the spline part of this shaft
4. The coarse tooth gear marked # 27 should fit on this spine shaft.
5. The steel pin in part A1 should fit into the end of the double gear unit- you will see that the small gears on A1 will engage the gear on the double unit and can move freely about the diameter.
5. The gear marked # 27 will now engage either the single gear or the double gear when you move the part A1- this gives you the forward- reverse rotation of the lead screw.
Not sure if A2 is part of this assembly or not- it may be a shift lever-
try to assemble the components as I described and shoot a picture.
Old 08-19-2011, 07:47 PM
mike96 is on a distinguished road
Thread is a little old but if you are still having any issues figuring out where all this stuff goes’ LMK. I have the exact same machine as you and I have all the gears set up on mine for the auto table movement. Although I may charge you a small fee, I have been having issues with the wiring on my machine... anyway I could get a couple of good pics of the switches and motors on yours.
Old 08-20-2011, 07:17 AM
LX Kid's Avatar
For "No Fee" I'd be willing to help you or anyone else with a problem they may have. Thanks
  #11   Ban this user!
Old 08-20-2011, 12:58 PM
My bad, I didn't mean to make that sound like I was actually gonna charge you something... sometimes it can be a bit tricky conveying what your intentions are on the net when you are tired. I will figure this Internet forum thing out eventually. what I meant by that last post was for the super low cost of a couple of pictures of your mill wiring I will be extra willing to help get your pile of parts figured out.
  #12   Ban this user!
Old 08-20-2011, 01:37 PM
LX Kid's Avatar
I understand. What pics can I provide you with of my wiring? With the heat out in my shop I haven't even been in there in about 3 months.
LinkBacks (?)
LinkBack to this Thread: http://www.cnczone.com/forums/shopmaster_shoptask/121449-shoptask_17-20_xmtc_parts_id.html
Posted By For Type Date
Shopmaster/Shoptask on CNCzone.com-The Ultimate Machinist Community | BoardReader This thread Refback 03-21-2011 05:13 PM
Shoptask 1720 XMTC add CNC mustangdug Shopmaster/Shoptask 2 11-29-2010 05:07 PM
Shoptask 1720 XMTC mill spindle runout? Knn Shopmaster/Shoptask 4 10-12-2010 12:50 PM
17-20 XMTC -? GunPilot Shopmaster/Shoptask 10 03-11-2010 05:16 PM
Shop Task Gunmaster 17-32 XMTC Worth getting? strykerakamack Shopmaster/Shoptask 13 01-14-2010 01:37 AM
Specs for cnc small parts - Shoptask Eldorado pfarber Shopmaster/Shoptask 2 12-09-2006 11:13 AM
