We have the Patriots with front mounted handle- its a pretty straightforward design. There is an angle bracket that bolts to the gearbox which holds the handle. The Handle shaft has ball thrust bearings on each side and a helical gear on the end. There is a helical gear on the lead screw as well. The mounting bracket has milled slots for the mounting bolts so you can adjust the gear mesh. Not sure what your configuration is, but it looks like all you would need to make this is the angle, the handle and shaft, 2 thrust bearings and a set of helical gears.
LinkBack URL
About LinkBacks
