Results 1 to 5 of 5
Thread: Threading mod to ElDorado mill
    Nov 2006
    What sounds more cost effective:
    Another mini-mill for threading tasks
    modify the eldorado to allow 'real' threading (not that guess where you start and keep guessing each pass nonsense).
    My unit has DRO, but am weary of even attempting to learn the 'shoptask threading method' if it could be overcome in the gearbox somehow.
    Any ideas???
    Are there any current bolt on options for a threading dial/half nuts?
    Jan 2008
    Quote Originally Posted by pfarber View Post
    Do you mean mini-lathe? If yes, anything that can be done on a mini lathe could more practically be done with taps and dies.
    You don't say which model year you have- on my old 17-20 ( 1995) model I cut a lot of threads on some pretty big pieces with no problem.
    It really sounds like you are resisting learning something new- I found that once I had used the shoptask method a few times it became quite easy.
    Any ideas???
    Give the shoptask method a try
    As far as I know, there never was such an option- the new machines do not have any gearboxes- its all done electronically.
    Nov 2006
    I really don't want to learn a s specific threading procedure for a machine that by most accounts can be difficult to thread with (I'm talking shoulders specifically).
    Then there is the issue of the 'manual' doesn't give more than a cursory explanation of of the 'shoptask way'... and I don't want to crash the tool post into the head and simply say 'well I learned that was bad'.
    Are there videos? Step by step guides?
    I've used the lathe for a number of boring and other projects, but only recently have I had any interest in threading with it.
    Feb 2009
    If the Shoptask is the only machine you have, then I think you need to come to grips with the fact that you only have 2 choices-
    1. Figure out what you've got or
    2. Buy something else.
    If you are not versed in threading, then you will still have a lot to learn even if you buy a traditional lathe with 1/2 nut design.
    Threading on a lathe is one of those operations usually restricted to the most experienced machinists in a shop because it requires a lot of practice.
    There is a book called " Screwcutting in the lathe" by Martin Cleeve which is very good in explaining the principles involved.
    Interestingly, the very first words in the introduction read;
    " It has been said that screwcutting cannot be taught from books--"
    Cutting a thread right up to a shoulder is not an easy task on any machine. I would suggest you try the method of threading away from the shoulder. Grab some scrap material and practice until you think you are ready to try on your project.
    Nov 2006
    Thanks all for your input.
    1. Shoptask Bridge Mill Eldorado
      By WildBillAZ in forum Shopmaster/Shoptask
      Last Post: 10-23-2012, 08:12 PM
    2. Problem- Eldorado Bridgemill mill head removal
      By leeharrysouth in forum Shopmaster/Shoptask
      Last Post: 03-18-2010, 05:02 PM
    3. CNC Threading on a mill ??
      By zaebis in forum General Metal Working Machines
      Last Post: 07-28-2009, 08:02 AM
    4. Help with threading on a CNC mill
      By shorety in forum General Metalwork Discussion
      Last Post: 06-13-2009, 10:15 PM
    5. Enclosure on a Eldorado Bridge mill
      By Rainman229 in forum Shopmaster/Shoptask
      Last Post: 03-08-2008, 12:59 PM
