- Need Help!- Help Programing multiple tools
I am trying to use three tools in one program, I am facing, drilling and parting a 7/8 aluminum hex stock. I open the tool table select a tool number jog my tool to touch off the z and the diameter. Enter the diameter in Part Zero X and hit enter for both Part Zero X and Z. Under the tool table editor I touch X and Z. Open the tool table and hit apply. I proceed with the other tools selecting a new number and touch them off the same way. When I run the simulator everything seems OK. The tool changes are selected by T0101, T0202 and T0303. It seems that the only tool that performs correctly is the last tool I touch off when setting up the tool table. I am in the Program Coords. when I set up my tools. I am trying to learn Mach3 what am I doing wrong.
- You may not post replies
- You may not edit your posts
Forum Rules
