ShopMaster Turnado Or Tormach Slant Bed Lathe
Results 1 to 8 of 8
Thread: ShopMaster Turnado Or Tormach Slant Bed Lathe
    Dec 2014
    Default ShopMaster Turnado Or Tormach Slant Bed Lathe
    I am considering purchasing one of these machines, PowerMaster Turnado or Tormach Slant Bed Lathe. I am only going to be using the machine for wood and plastic turning. I know I could use a manual woodworking lathe but injured my hand using one. I also want something that prevents chips from flying everywhere. Does anyone have either of these machines? Are there any advantages or disadvantages? The Tormach is twice the price but the quality of build seems to be better.
    Anyone in the Cleveland, Ohio area have one of these?
    Thanks.
    Jul 2005
    Default Re: ShopMaster Turnado Or Tormach Slant Bed Lathe
    Quote Originally Posted by Pjblues1 View Post
    Thanks.
    If your budget was 15-20K and you wanted to produce precision metal parts, then I would say the Tormach would be your choice. However, for woodworking you need certain features like a large swing for bowls and a long center distance with a tailstock for things like spindles and table legs etc. In this area the Turnado is the better choice- in fact I don't think the Tormach even offers a tailstock. The Turnado also comes in at around 5K, so you could buy 3 or 4 of them with that kind of budget. Why not go with a CNC wood lathe as in this video- it is specially made for woodworking and is about the same price as the Tormach.
    Gold Member
    Jun 2006
    The Tormach Slant Bed lathe does offer a tailstock but it may limit the Z travel even more than it already is.
    For the OP - what top of turning do you want to do? What's the largest OD and length you want to turn? How many tools do you expect to use in one job?
    FWIW, the cover on the Turnado that is shown on their web site makes it look like a lot chips could escape through the gap; the Tormach lathe can be completely enclosed if you opt for the full enclosure.
    Feb 2009
    For a 5K budget go for the Turnado
    For a 15K budget go for the Laguna- a no compromise full blown CNC wood lathe.
    Chips- anyone who has ever worked in wood will tell you that they cannot be contained.
    Dec 2014
    Thanks so much. I called Laguna yesterday and inquired about the machine. It is fantastic. The only draw back is you cannot do a bowel on it.
    Feb 2009
    OUCH- the thought of a "bowel" on a lathe sends shivers down my spine.
  7. #7
    Dec 2014
    Turning bowls on a wood lathe is how I severally damaged my hand, and I was a good wood turner. Lose focus and things go very wrong.
    So I turned a bowel on my CNC router this week, just to prove it could be done. I turned it in a vertical position using a 1/2" end mill. with 4.5" of flute length. I turned the outside first and then the inside, faced it off and it was done. It look awhile to do but it turned out great. So now I am thinking a metal lathe for small spindle turnings, etc.
    Thanks everyone.
  8. #8
    Mar 2003
    This is the case with most woodworking tools.
    Don't pay attention, and you lose fingers.
    UCCNC 2017 Screenset
    http://www.thecncwoodworker.com/2017.html
    http://www.thecncwoodworker.com/2010.html
    http://www.g-forcecnc.com/jointcam.html
