- Need Help!- mach3 screen
mach3 screen
Although this is not a huge problem, it can be annoying. I have mach3 on 2 computers. The one the runs the CNC show the image as slightly distorted, IE. a circle as an oval, with it being long on the X axis. It does produce the machined material correctly though. Just wondering why, and how to fix. thanks.
Re: mach3 screen
I think if you check"reversed arch's in front tool post" , it gets rid of that. Config> Ports and Pins> Turn options
- You may not post replies
- You may not edit your posts
Forum Rules
