- 5C COLLET SYSTEM, 3 JAW AND 4 JAW CHUCKS
Here is a short video showing the 3 jaw chuck, 4 jaw chuck and 5C collets available on the 2017 Mill Turn and Turnado machines. All three are standard items on the Turnado lathe, while the 5C collet set and the 4 jaw chuck are options on the Mill Turn. Our idea was that for those looking for a lathe specific machine we would make it as complete as possible, while those looking at the combination machine could choose options leaning to either lathe or mill work as they prefer. We also sourced a new 4 jaw chuck that has the same mounting pattern as the 3 jaw, making the changeover quick and easy. Our use of collet blocks in the chucks is a bit different, but we feel that it makes using the collets faster than changing to a dedicated 5C chuck, and by using the 4 jaw with the square collet block, the accuracy of the system can be dialed in by the operator to whatever degree he wants.
- You may not post replies
- You may not edit your posts
Forum Rules
