CUSTOMER MODS ON MILL TURN BENCH
Results 1 to 5 of 5
Thread: CUSTOMER MODS ON MILL TURN BENCH
    Dec 2007
    Default CUSTOMER MODS ON MILL TURN BENCH
    A customer sent us some pictures of a modification he did to his bench. Real nice work. He used solidworks for the design and says he can supply the files for anyone wanting to make one themselves.
    CUSTOMER MODS ON MILL TURN BENCH-mounce-bench-1-jpg
    CUSTOMER MODS ON MILL TURN BENCH-mounce-bench-2-jpg
    CUSTOMER MODS ON MILL TURN BENCH-mounce-bench-3-jpg
    CUSTOMER MODS ON MILL TURN BENCH-mounce-bench-4-jpg
    CUSTOMER MODS ON MILL TURN BENCH-mounce-bench-5-jpg
    Member RussellCofID's Avatar
    May 2016
    Quote Originally Posted by JTJT View Post
    That looks SOLID. Well if there was ANY problem with rigidity, it's gone now!
    I appreciate you posting these things JT, I have an old 12-22 I bought used in the '90's and if a couple projects work out right I hope to be upgrading!
    Russell C of Idaho
    Big trains and big dreams...
    May 2016
    Default Re: CUSTOMER MODS ON MILL TURN BENCH
    I'd love to get a copy of the drawings for this mod. How do I get in touch?
    Jul 2004
    Any way to get the file on this. It would be a great upgrade.
    Member deadlykitten's Avatar
    Jun 2015
    Antarctica
    hy just sketch a table, from profiles ( square and L, thickness >=5 ), that is strong enough to hold all your toolings + machine
    on the final shelf, where the machine is, make sure that the profile is not higher than the shelf surface, or it will be harder to clean it, and there will always be chips at the corners
    instead of 4, use 6 'pads' ( with adjustable height ) to make contact with the ground ( thus 2 more in the middle ), and be sure that those can handle uneven terrain, even if your floor is flat, because the welded structure may be buckled
    enough ground clearance, for a forklift and/or hand pallet truck, etc
    cut a few holes, to assure fresh air inside the cabinet
    break sharp edges, paint it / kindly
    ps : if you wish to truly go next-level, mask all the screws, and use welded nuts
    we are merely at the start of " Internet of Things / Industrial Revolution 4.0 " era : a mix of AI, plastics, human estrangement, powerful non-state actors ...
