I am going to order the more expensive unit and give it a try. It has a nice set of controls and automatically raises and lowers the air motor to engage the drawbar. It looks like a pretty easy mount up, only needing to machine some standoffs to raise the mount up over the belt, and maybe a re-do of the spindle sensor bracket, then cutting away some of the top sheet metal cover. I will also make a new drawbar with a heavy duty 19 MM hex head, tapered to center in the spindle, and with a tapered pilot on the threaded end to center in the collets.
