- AC servo conversion on CNC Patriot VFD machine
Re: AC servo conversion on CNC Patriot VFD machine
This is a very elaborate and technical endeavor! very neat stuff here. I hope it works out and will try to stay tuned on this one! Using the output of the glass scales for your positioning was a really neat way to go. On another site, there are a few guys who went with the Magnetic tape and readers by Renishaw for their positioning and it worked out well.
Keep us posted!
CG
After a spending my time on other projects, I am working on finishing the conversion. I finished the x-axis conversion listed above. I tuned the motor and it responded pretty much on the mark within +-20um. However, when I send the motor random and more erratic jogging motion some position error accumulates, and so far I have not been able to identify the source. I measured the mach3 output and the pulse widening (via arduino MCU) and both are consistent with Mach3 readout. Maybe it's a synchronization error between arduino output (mach3 pulses) and drive pins reading (which is 500Hz). I did order a replacement servostar drive from ebay as an alternative. But first I may try to find for sure if it's a synchronization error and if so then synchronization the two.
I wasn't able to get the dual loop position feedback working on the SC954 so I bought two Servostar CD 2 series drives to try. Those drives turned out to be not usable for such input positioning speeds (even though the position loop update rate was 2kHz). I'm think that these two types of drives just aren't meant for that type of input speed under the dual loop configuration. A newer drive may work (kollmorgen recommended a newer drive). For now I got the single loop motor feedback working well in no time with the servostar cd on the x-axis. I'm going to hookup the other two motors next. I'm happy with the speed and resolution of the x-axis. So I have 2 extra drives...and i'm going to use one to replace the lathe motor (as the low speed torque is not the best). Going to sell the other one on ebay or here if anyone is interested SC933 for $200. Just a preview; I was thinking of going with one of those water cooled chinese spindles (3kW) as a replacement for the mill spindle (0-24krpm). That's all for now.
I installed the y-axis motor and it is working well with single loop resolver feedback. One motor to go.
The next step is to attempt to add an external position loop using raspberry pi 2/3 computer/board. I'm waiting for some decoder chips still for the glass-encoder-scale output signals (this is the current bottleneck). I know this coveted dual position loop can be done with kflop, but I prefer to do a custom outer position loop, and it's cheaper (just $60 for a raspberry pi). This can even be implemented with stepper motors to achieve accuracy at the resolution of the glass-scale-encoders. I don't know if the machine components are rigid enough for such a setup, but I want to try to do all 3-axis (the z-axis especially cleans up when the spindle-lock partially tightened).
I worked night and day on this and finally finished a control system using the Raspberry Pi3 computer. It detects Mach3 step/dir control signals and encoder scale feedback signals using wiringPi interrupts on the GPIO pins and having PID output step/dir signal to the drive. It took a lot of iterations and tries, but the I managed what I think an excellent wiringPi pseudoPID code (that turned out to be short and compact) which keeps it within 2 thou over 200mm or so with super smooth motion, which I thought was pretty good. It works quite well. I'll upload the code when I get time. Some pictures too. This can be implemented in a stepper setup too. This is done solely with a $40 Raspberry Pi board and an instrument amplifier on each of the A and B encoder channels to ensure 0 to 4V signals to the Raspberry Pi board (the the feedback decoding is done in software on the Raspberry Pi (those chips never still haven't arrived)). The board also has to be grounded to the GPIO ground pins. I think the board will work for at least 2 of the axis and I may need a second for the last axis. Maybe all three will work on one board. Next, i'm going to try the position loop on the drive next to see how it compares to the Raspberry Pi board. Maybe better feedback signals to the drive will make it work.
Re: AC servo - Patriot - hi res
Most excellent thread !
Most excellent work !
I highly applaud Your understanding of the electronics, signalling, developing and debugging the system.
And most especially the persistence You have shown.
Extremely Well Done - imho.
My next post re: previous is multi-faceted.
My interest has been making industrial "best" threads on a lathe.
Your stuff is the only one that seems to use the glass-scale encoders for feedback ?? that I know of..
(And I plan for very high accuracy milling results on a CNC VMC I built).
Situation.
I use a csmio-ip-s hw controller for motion control on the lathe.
It supports, in theory, glass scale secondary feedback.
Current servos are at 500 kHz and very powerful.
I plan to, and likely will/may buy 1 micron, or 0.1 or 0.01 micron, glass scales for feedback.
About 450 mm on z, 150-200 mm on x.
I am looking for advice, gotchas, etc..
As all the stuff is expensive, I really hope to get results related to costs ...
I'll let you know what I get on the secondary feedback on my drive (CD servostar 250). So far my best solution was a Pacific Scientific SC905 drive with the positioning card. Although the Raspberry Pi is not bad how I had it setup.
It looks like the CSMIO/IP-S does not accept any sort of feedback (just the CSMIO/IP-A does...and that will only work for you if your servo drives accept analog input). Your other option is secondary feedback on your servo drive itself as opposed to the motion controller.
An update! I decided to drop the dual loop for higher accuracy and use a single loop with motor encoder (or resolver) feedback. I had the raspberry pi working pretty good in a psudo-PID control as an outer position loop controller (glass-scale encoder position feedback that accepts commands from Mach3 and outputs a signal to the motor drive) but in-spite of the fact that the raspberry pi had great compact program i wrote in wiringPi (i think...it's been awhile...i think that's what it was called) and great interrupt based pins (on the raspberry) to accept the encoder signal, the raspberry would miss pulses from the glass-scale encoder and accumulate error. Because of this and the fact that motor encoders/resolvers are more robust than that on a glass-scale I decided to go with the more common single loop with motor feedback. Attached are a couple pics of the shoptask-Patriot-VFD machine working well with AC servo motors, and I learned some artcam basics to make a nice little plaque. I'm going to make a 3D lizard next and make my own 2.5D plaque great designs after that (if i can...i'll give it a try).
- You may not post replies
- You may not edit your posts
Forum Rules
