Hello,
Looking to see of anyone knows of a better bearing that a 6008rs bearing for percision? I pulled mine from the bearing/pully assembly that is on top of the mill section of the Shopmaster I found upto 5 thou play in mine that may help with the wobble we are seeing in the z axis. Here is a pic of it apart. I also found that they made stake/Pin marks in the pully that kept the bearing from spinning in the pully half so it fit snug. I will use loctite when I reassemble it to kep it in place and from moving out of round like I saw with a 10 thou wobble because not in alignment.
