Go Back   CNCzone.com-The Largest Machinist Community on the net! > MetalWorking Machines > Sharp CNC
Sharp CNC Discuss Sharp CNC Machines Here!
Old 12-21-2009, 08:16 AM
Larry Myers is on a distinguished road
cutter compensation values
Hi all
I have been trying to figure out if there is a way to assign multiple cutter compensation values to the same tool, within one program.
Larry
Old 12-21-2009, 01:59 PM
dcoupar's Avatar
You can use any offset with any tool, either for length or for diameter comp.
For length comp, you start with:
G43 Z0.1 H01 (MOVE TO Z0.1 AND ACTIVATE OFFSET 01)
G01 Z0 F20.
X2.0
Z0 H21 (MOVE TO Z0 AND ACTIVATE OFFSET 21)
X0
There are parameters in the control that determine how and when the new comp is applied, so be careful the first time through and work above the part.
For diameter comp, I've used one offset for roughing a profile, then another offset for finishing.
G43 Z0.1 H01
D21 F20. (SET OFFSET # AND FEED FOR ROUGHING)
M98 P1001 (CALL PROFILE SUB)
D01 F30. (SET OFFSET # AND FEED FOR FINISHING)
In your sub, you'll have the G41/G42 and G40 commands to turn cutter comp on or off.
Hope this helps.
Old 12-21-2009, 11:20 PM
Thanks Dcoupar
I'll see what I can do with that.
Thanks again,
Larry
Cutter Compensation TravisR100 NCPlot G-Code editor / backplotter 2 10-31-2010 03:09 PM
Cutter compensation.. driftmaster Mastercam 18 04-03-2010 03:14 PM
Cutter compensation???? Clawsie Machine Cincinnati CNC 6 11-13-2008 02:19 PM
cutter compensation functionbikes Tormach PCNC 2 06-17-2008 03:39 AM
Cutter compensation? Tonenc G-Code Programing 4 11-03-2005 12:53 AM
