Go Back   CNCzone.com-The Largest Machinist Community on the net! > MetalWorking Machines > Sharp CNC
Sharp CNC Discuss Sharp CNC Machines Here!
Old 10-26-2009, 12:32 AM
rbcmetalwork is on a distinguished road
MDI problem
Hello there,
I just purchased a used 2004 SV2412 for my garage shop. This machine has the Fanuc Oi Mate-MB control (my first experience with Fanuc). I'm having a problem with using MDI. I can write a simple program in MDI mode to turn the spindle on but when I press [Cycle Start] nothing happens.
O0000 M03 S1000 ;
M99
I can turn the spindle on manually in jog or handwheel mode. I also ran through the built-in diagnostics with no problems. Any help would be greatly appreciated.
Thanks,
RBC Metalwork
Honolulu, Hawaii
Old 10-26-2009, 06:01 AM
mif73 is on a distinguished road
Interlock?
Hello, try something simple like coolant on/off first,(M08/M09) just in case it's a safety interlock preventing auto use (door open, low air pressure, low hydraulic/low slide oil/ low spindle oil etc stopping the spindle from running).
Otherwise does it work ok if you write a program in auto mode and run it?
Some machines are picky about the order of code too, for example you may have to issue the S code then the M code (S1000 M03, but it should run ok if on the same block)
Hope you have some good luck, Cheers.
PS: How's the weather this time of year ?
Old 10-26-2009, 06:30 AM
CNC-Hammer is on a distinguished road
In MDI mode you should only need to issue the M03 and S1000 and then cycle start after the commands have been input.
It appears you are writing a program in the example given so try an M02 or an M30 instead of M99
Old 10-26-2009, 10:11 AM
Larry Myers is on a distinguished road
I have a 2412 as well. Try this:
S1000 M03; and nothing more.
Insert and puch START CYCLE
Good luck
Larry
Old 10-26-2009, 10:30 PM
LatheMaster's Avatar
LatheMaster is on a distinguished road
Larry and RBCMetalwork , How much did you get your machines for ? New or Used ? Will they run well on single phase 220 ? How would you compare them to a Fadal VMC-15 ?
Old 10-26-2009, 11:17 PM
bruce_hurco is on a distinguished road
Please delete M99
Good lucky
Old 10-27-2009, 02:34 AM
MDI works fine now
Thank you for all the replies. It works now. I think the problem was that I wasn't waiting for the two clicks on startup.
mif73 The weather's fine. Mid to upper 80s during the day and mid 70s at night.
LatheMaster, I got mine used for $20K. The $4600 shipping to Hawaii was the hard part. I'm using a Phase Perfect phase converter. It's costly but very nice. Sorry, I don't have any experience with Fadal.
machine problem or software problem? bcnc Syil Products 8 10-26-2009 10:51 AM
