Go Back   CNCzone.com-The Largest Machinist Community on the net! > MetalWorking Machines > Sharp CNC
Sharp CNC Discuss Sharp CNC Machines Here!
Old 07-21-2009, 07:54 PM
freeflyer is on a distinguished road
Retention knobs
I just recieved my sharp 2412. I'm trying to find out if the manual has a misprint on the retention knob print, as it seems to be an uncommon size. The dia. between the flange and the knob on my print says it's 9.8mm or ~.386". But the common size is .490". Can someone with a 2412 confirm the retention knob size.
Thanks for the help,
Michael
Old 07-22-2009, 11:06 AM
dcoupar's Avatar
Everything I have on the 2412 specifies a Valenite PT-475 pullstud. See attached .jpg.
Name:	Valenite CT-Retention Knobs.jpg‎
Old 08-09-2009, 09:32 PM
Trent Steel is on a distinguished road
0.392 is actually fairly common. It's an adaptation of a BT40 pull stud but with the 5/8-11 thread to fit CAT40s.
However, I think you may be right that the 2412 uses the .490 size. What did Sharp say about this?
Old 09-14-2009, 10:59 AM
krfrea is on a distinguished road
I have been using the .490 for 2 years now with no problems at all.
Old 09-17-2009, 10:06 AM
It is the .490. Thanks everyone.
Ever used these retention knobs? rawen2 Haas Mills 5 09-19-2008 11:41 AM
Need Help!- Retention Knobs for Mitsui Seiki VR 3A barchdesigns CNC Tooling 0 07-07-2008 12:57 PM
Need Help!- RETENTION KNOBS Jfrahm CNC Tooling 3 05-31-2008 09:07 AM
Control knobs for musical instruments munich2007 Moldmaking 9 11-28-2007 09:20 PM
Shift knobs hot knobs Trade Shows and Events 2 08-12-2007 08:34 AM
