| Sharp CNC Discuss Sharp CNC Machines Here! |
| Sharp SV 2412s Question Thd Milling Can someone send me a sample of a thread mill operation? I need to compare this to what our CAM software (Bobcam) is posting . The problem is that the thread mill does not want to travel helical Z. Sharp said I am missing a "G33" ? This is the post that "Bobcam" provides (JOB 2 THREAD MILLING) (TOOL #3 0.3720 THREAD MILL) N59 T03 N60 M06 N61 T01 N62 G90 G54 X0. Y0. S841 M03 N63 G43 H03 Z.1 M08 N64 G01 Z-2. F3.3679 N65 X-.186 Y.5 N66 G02 X.314 Y0. I0. J-.5 N67 X.314 Y0. I-.314 J0. N68 X-.186 Y-.5 I-.5 J0. N69 G01 X0. Y0. Z13. N70 G00 Z.1 N71 M09 N72 M05 N73 G28 Z0. N74 G59 X0. Y0. (END OF FILE) (END OF PROGRAM) N75 M30 % |
| Hello Arcticigloo ,I also have a sharp 2412 , G33 does not apply to threadmilling its more for single point thread cutting. It looks like your cuting a 1 inch dia thread don't know the pitch. The program looks wrong line N65 will place the cutter well outside the 1 inch circle. Also theres no Z while cutting therefore no movement. Also the cutter should climb out of the hole G3 insted of G2 Lets say you want to threadmill a 1x 10 tpi . 5 deep thru hole with no cutter comp. and no lead in or lead out . (JOB 2 THREAD MILLING 1 X 10 TPI) (TOOL #3 0.3720 THREAD MILL ) T03M6 G0 90 G54 X0 Y0 S1000 M3 G43 H3 Z.1 M8 G1 Z-.650 F50 X-.314 F5 G3 I-.314 Z -.550 G1 X0 G0Z6M9 M30 Note G3 I-.314 Z -.550 cuts a full circle while Z rises 1 full pitch.
__________________ Tim Last edited by timlkallam; 04-11-2009 at 01:54 AM. |
| It might be the same reason thar my high speed maching was not working. if you open your post and look on line 64 you should have somthing like x_f,y_f,Z_f,. This teels the z to post in a three axis arc. If your using v23. I have a sharp also but only used it for the high speed maching and it would not put a z on any lines with a g2 or g3. |
| Sharp CNC V 2412 Question | pshsguy18 | Sharp CNC | 21 | 01-22-2010 10:15 PM |
| Need Help!- Sharp ST-10 Lathe Question | arcticigloo | Sharp CNC | 1 | 03-16-2009 10:04 AM |
| Getting close to pushing the button.... (SV-2412S) | spencer313 | Sharp CNC | 0 | 04-19-2008 10:36 PM |
| Sharp SV- 2412 CNC Machine Question | pshsguy18 | General Metal Working Machines | 3 | 02-16-2008 12:35 AM |
| 2412s super mini | PBMW | Sharp CNC | 35 | 10-09-2007 08:37 PM |
