| Sharp CNC Discuss Sharp CNC Machines Here! |
| I don't use Surfcam, but it's just a Fanuc post..... I'm sure if it's anything like Mastercam that there are 12 different Fanuc posts on teh install disc |
| As already stated, you can use most any fanuc post, or yasnac. All you have to do is change from next tool programming by deleting the tool call up on the prep/cancel line, and put in a TxM6. if you don't put the tool change before the prep/cancel block, be sure to use a G90 in your first move, since the Sharp control uses a G91 sub program for the tool change. Additionally, you have to put a M29 Sxxx (spindle speed)in the block preceeding your G84 block for rigid tapping. |
| Sharp Mill retrofit | RJ. | Vertical Mill, Lathe Project Log | 39 | 03-12-2011 01:58 AM |
| Sharp SV-2412 | Larry B. | CNC Machining Centers | 18 | 10-12-2007 09:58 AM |
| Sharp CNC New Forum | Rekd | Sharp CNC | 0 | 03-13-2007 04:55 PM |
| Sharp internal corners | Sanghera | General CAM Discussion | 18 | 03-30-2006 03:46 PM |
| Sharp LMV z-axis cnc? | tltaylor | Bridgeport and Hardinge Mills | 0 | 09-22-2005 06:00 PM |
