Go Back   CNCzone.com-The Largest Machinist Community on the net! > MetalWorking Machines > Sharp CNC
Sharp CNC Discuss Sharp CNC Machines Here!
Old 11-25-2010, 05:53 AM
mcv300 is on a distinguished road
air compressor recomendation
Hi all, could you suggest motor size (hp), capacity (l/min) and storage tank capacity that is required for sharp 2412
can a 3hp, 150 l/min , with 90l capacity satisfy the requirement ?
I don't want the compressor work all the time
Old 11-26-2010, 05:52 AM
timlkallam is on a distinguished road
I have a sharp 2412 it doesn't uses much air you should be fine .
Tim
Old 12-12-2010, 10:29 PM
Thank you Tim
Old 12-29-2010, 03:14 PM
krfrea is on a distinguished road
iair consumption
Please remember that you will be using air to blow chips etc. off your parts as you remove them besides the air the cnc uses. I have a Sharp SV2412 and use a 220 volt 2 cylinder 5 hp commercial compressor and it keeps up just fine but it runs a lot. I think your 3 hp may have trouble keeping up.
Old 01-12-2011, 06:57 PM
rbcmetalwork is on a distinguished road
I too have an SV-2412. My compressor is a 5hp rotary vane with a 60 gallon receiver. The compressor is rated at 100% duty cycle and when I'm machining it runs more than it rests. In addition to the machine's air demands and blowing chips I'm using a minimum quantity lubrication system which uses additional compressed air.
Randy
SV-2412, 0i Mate-MB
Old 01-13-2011, 02:23 AM
Thanks for your recommendations
I am using 3hp compressor with 150l tank now , so far it is sufficient .
Coolant recomendation JasonR Haas Mills 38 03-26-2009 03:14 PM
VFD recomendation Danno Phase Converters and VFD 9 11-17-2008 11:07 AM
CPR PPR recomendation wcarrothers DIY-CNC Router Table Machines 2 08-31-2006 03:04 PM
Machine Recomendation Tim J CNCzone Club House 3 04-01-2006 12:46 PM
EDM Recomendation Tim J CNCzone Club House 0 10-26-2004 06:16 PM
