Go Back   CNCzone.com-The Largest Machinist Community on the net! > MetalWorking Machines > Sharp CNC
Sharp CNC Discuss Sharp CNC Machines Here!
Old 04-17-2010, 03:11 PM
RonRoy2004 is on a distinguished road
Spiral Pocket Milling SV24-12 Super Mini w/ Fanuc Oi Mate-MC
Hello,
After a year and a half I haven't had any luck finding info thru Sharp so am asking here, I can use the pocket functions to make a circular pocket, if I want it to step straight over then make the loop, however I am attempting to make a pocket by feeding to depth, then spiraling out to finish size to ease cutter load and have a precise finish by ramping in and out rather than plunging.
Does anyone know of a macro for this that works? or am I stuck remote programming this with BobCad?
The macro sharp provided makes rectangular pockets and even it steps out in one axis, lol.
Thank You
Ron Riekens II
ronroy2004@comcast.net
Old 04-17-2010, 05:44 PM
leggazoid is on a distinguished road
From leblond makino world of macros book. Look for book on ebay. Wish someone had it in pdf.
:0113 (SPIRAL MACRO)
#26= ABS[#26]
#17= ABS[#17]
#22=#17
IF [#26 EQ #0] GOTO 1 (Z)
IF [#17 EQ #0] GOTO 1 (Q)
IF [#18 EQ #0] GOTO 1 (R)
IF [#4 EQ #0] GOTO 1 (I)
IF [#7 EQ #0] GOTO 1 (D)
IF [#20 EQ #0] GOTO 1 (T)
IF [#3 EQ #0] GOTO 1 (C)
IF [#19 EQ #0] GOTO 1 (S)
IF [#13 EQ #0] GOTO 1 (M)
IF [#26 EQ #17] GOTO 2 (Z LESS THAN E)
#33= #4001
#32= #4003
#31= #[2000+#7]
#30= [3.82*#19]/[2*#31]
IF [#30 GT #13] GOTO 8
S#30 M3
#29= #30*#20*#3
GOTO 9
N8 S#13 M3
#29= #13*#20*#3
N9 #27= #18/12
#10= #5041
#12= #5042
#5= #5043-#5083
#16= 0
G17
N7 #14=#17
WHILE [#26 GE #14] DO 1
IF [#31 GE [[#11/2]-.05]] GOTO 4
#28= [#11/2]-#31
G91 GO Z-[.1+#17]
G90 X[[#10+#28]-.05]
G1 X[#10=#28] F#29
GOTO 5
N4 G91 G1 Z-[.1+#17] F[#29/2]
#28= 0
N5 #15=[[#4/2]-#28-#31]/#18*360
#1=30
#28= #28+#27
WHILE [#15 GT #1] DO 2
#24= #10+#28*COS[#1]
#25= #12+#28*SIN[#1]
#2= [#28/[#28+#31]]*#29
G90 G3 X#24 Y#25 R#28 F#2
#1= #1+30
#28= #28+#27
END 2
#28= [#4/2]-#31
#24= #10+#28*COS[#15]
#25= #12+#28*SIN[#15]
X#24 Y#25 I-[#28*COS[#15]] J-[#28*SIN[#15]]
#15= #15+15
#24= #10+#28*.98*COS[#15]
#25= #12+#28*.98*SIN[#15]
X#24 Y#25 R[#28*.98]
IF [#26 EQ #17] GOTO 6
IF [#26 EQ #14] GOTO 6
IF [#16 EQ #1] GOTO 6
G91 GO Z.1 G90 X#10 Y#12
#14= #14+#17
END 1
#17= [#26-[#14-#17]]
#16= 1
GOTO 7
N6 GO Z#5 X#10 Y#12
#17= #22
GOTO 3
N1 #3000= 0(SPIRAL POCK. COMMAND INCOMPL.)
N2 #3000= 0(E EXCEEDS Z)
N3 G#33 G#32 M99
Old 04-17-2010, 06:32 PM
christinandavid's Avatar
christinandavid is on a distinguished road
Helical Macro - Linear Motion
Have been writing a macro to perform these kind of motions in an incremental linear fashion to allow freedom using rotation (to suit our milling head attachment).
Was surprised to find that I can use it to describe virtually any kind of motion - facing, pecking, involute (pocketing), helical (polygonal, not just circular) and trochoidal.
Pocket-wise, you can start wherever you want. Slot-wise, you can oscillate the feedrate to reduce air-cutting. I have also added a start/finish angle which can be used to reduce cutter engagement in the corners. I can post it to you with an explanation once I've perfected the cutter-comp.
DP
Old 04-18-2010, 09:26 AM
dcoupar's Avatar
leggazoid,
Thanks for posting this. I don't suppose they had any examples of calling the macro?
Old 04-18-2010, 10:06 AM
mactec54 is on a distinguished road
Hi RonRoy2004
Here is a 2.0 hole .600 deep with a arc-on & arc-off, Macros are great if you know how to do them or you want to spend the time to learn how to do them, as well your control has to support them, not all can
File Type: txt Zone Spiral for 2.0 Hole.NCF.txt‎ (272 Bytes, 177 views)
Mactec54
Old 04-18-2010, 05:28 PM
Yes they did have an example of calling it with 2 pictures that explained it. This program is written for inch programming only. I don't have access to these right now but I will try to explain the g65 call...
Start at Z.1 above part.
z = final z depth
q = z increment
d = cutter comp offset
s = sfm
r = ?
i = diameter of finished hole
t = # of teeth
c = feed per tooth?
m = maximum spindle speed
Can someone with macro experience help with r?
Old 04-18-2010, 10:31 PM
skullworks is on a distinguished road
Basic G13 function
I wrote a macro to ADD G13 to our Mori Seiki SV50B and based it on the Yaznaq implementation which is sparse compaired to the Haas implementation.
At the time I wrote it I had not had to stoop to running Haas machines in production.
The G13 macro was assigned O9013 and became a fully functional G-code cycle like G83.
I used alot of machine variables to plug in the last active F, D, current position etc. I also have many error tests that will cause an alarm if you don't use it properly.
The G13 can be used for circle cleaning/finishing or a full spiral pocket. My macro does EVERYTHING at a fixed Z, Meaning you have to position to hole/pocket center and plunge to depth BEFORE doing the G13 cycle. Also its up to the programmer to retract the tool once the pocket is done. It was a bit rushed and could use some refinement but it has worked fine for us.
I will try to grab a copy.
Need Help!- Spiral Milling NickDP G-Code Programing 7 09-27-2011 10:30 PM
MACRO FOR HOLE SPIRAL MILLING ALEXCOMO Fanuc 32 06-23-2011 06:37 AM
Sharp sv24-12 with 0i mate control milling 3D zosotd Sharp CNC 5 11-30-2010 02:12 PM
Fanuc pocket milling macro tturnbull50 G-Code Programing 4 08-30-2010 02:48 AM
Spiral pocket function LongRat SheetCam 2 12-28-2006 07:31 AM
