Sharp CNC
Page 1 of 6 1234 ... LastLast
Threads 1 to 20 of 113
Forum: Sharp CNC
Discuss Sharp CNC Machines Here!
  1. Need Help!- SV 2412 Losing Absolute Zero
    Started by JarrettP‎, 11-21-2017 03:03 PM
    absolute, losing, machine, origin, stays
    11-21-2017, 03:03 PM Go to last post
  2. Need Help!- Draw bar
    Started by ivanjaramillo‎, 10-02-2017 10:53 PM
    bar, draw, sharp, sv2412, washers
    10-02-2017, 10:53 PM Go to last post
  3. Question Need Help!- Rigid Tapping not working right.
    Started by DavidHPI‎, 04-07-2016 10:47 AM
    rigid, sharp sv2412, tap
    07-01-2017, 10:57 PM Go to last post
  4. Problem- Machine treats feed as rapid after tapping
    Started by MGA01‎, 12-02-2012 04:43 PM
    away, spindle setting, then
    07-01-2017, 01:48 AM Go to last post
  5. Problem- Tool Changer out of sequence Fanuc Oi-MC Control
    Started by ren3600‎, 01-13-2016 06:26 PM
    carousel, match, number, pocket, tool
    07-01-2017, 01:12 AM Go to last post
  6. Need Help!- SV2412S Tool Carousel is Posessed
    Started by JarrettP‎, 04-06-2016 02:41 PM
    carousel, machine, power, sv2412s, tool
    07-01-2017, 01:05 AM Go to last post
  7. Post Newbie- SV2412 M-code for Chip Auger
    Started by dpetit28‎, 01-12-2015 12:54 PM
    auger, chip, chip auger, chip conveyor, code, hi all, m-code, machine, question, said, sharp, sta, standard, sv2412
    07-06-2016, 03:05 AM Go to last post
  8. tool magazine won't go forward
    Started by mcv‎, 07-01-2016 10:19 AM
    airhose, forward, magazine, manual, tool
    07-05-2016, 11:27 AM Go to last post
  9. How setting tools and setting offset
    Started by John246‎, 03-15-2010 12:56 PM
    everyone
    04-09-2016, 04:31 PM Go to last post
  10. looking for manuals for sharp 2412 fanuc IO mc mate
    Started by Gunner52‎, 09-14-2015 09:50 PM
    fanuc, machine, manuals, mate, sharp
    02-29-2016, 07:03 PM Go to last post
  11. Need Help!- Source for replacement rubber wipers
    Started by DavidHPI‎, 02-18-2016 10:17 AM
    covers, parts needed, rubber, source, wipers
    02-18-2016, 10:17 AM Go to last post
  12. Coolant foaming problem
    Started by Larry Myers‎, 10-09-2007 07:51 PM
    3 Pages
    1 2 3
    mos
    01-26-2016, 04:55 PM Go to last post
  13. Having Problems when Z axis is referencing home
    Started by 72volvo145‎, 08-13-2015 08:40 PM
    axis, day, issue, mill, night
    08-21-2015, 12:27 AM Go to last post
  14. Question Need Help!- Memory Card Error 99 SV2412s
    Started by 72volvo145‎, 01-11-2015 05:38 PM
    card, controller, memory, setting, sharp
    08-13-2015, 08:31 PM Go to last post
  15. Thoughts on a Sharp 2416?
    Started by Harbor‎, 07-16-2014 08:41 PM
    look
    01-12-2015, 11:24 PM Go to last post
  16. sv-2412 spindle parameters
    Started by wallygator63‎, 01-05-2015 03:19 PM
    200, 412, 60devious, 60rpm, devious, ers, locking, parameter, parameters, pas, past, rpm, runs, set, spi, spindle
    01-05-2015, 03:19 PM Go to last post
  17. Need Help!- Sharp retrofit CNC mill problems
    Started by Stephen Samuels‎, 06-18-2014 06:47 PM
    saying, x y
    06-18-2014, 06:47 PM Go to last post
    04-06-2014, 11:57 PM Go to last post
  18. spindle chiller ?
    Started by D.D.Machine‎, 03-13-2014 12:14 AM
    03-17-2014, 01:34 AM Go to last post
  19. Need Help!- need 2412 SRAM files
    Started by spock‎, 02-20-2014 09:37 AM
    since
    02-20-2014, 09:37 AM Go to last post
Forum Information and Options
Moderators of this Forum
Users Browsing this Forum
There are currently 2 users browsing this forum. (0 members & 2 guests)
Thread Display Options
Use this control to limit the display of threads to those newer than the specified time frame.
Allows you to choose the data by which the thread list will be sorted.
Order threads in...
Note: when sorting by date, 'descending order' will show the newest results first.
Icon Legend
Contains unread posts
Contains no unread posts
More than 25 replies or 500 views
Hot thread with unread posts
Hot thread with no unread posts
Closed Thread
Thread is closed
Thread Contains a Message Written By You
You have posted in this thread
