Results 1 to 11 of 11
Thread: Help: 5 Servo motors.. can't find details??!!
    Registered JohnnyVegas's Avatar
    Jun 2009
    I have come into a box of servo motors but can't find a thing on them. I looked up all info and serials I can.
    All I know is the guy I got them from had them for a while and says he thinks they came from large industrial or commercial printers
    Here is a picture of one.
    Help: 5 Servo motors.. can't find details??!!-cimg4148.jpg Help: 5 Servo motors.. can't find details??!!-cimg4146.jpg Help: 5 Servo motors.. can't find details??!!-cimg4147.jpg
    What should I do with these? I can't find any info at all.
    Jun 2009
    Here is the most info I can find. It's not much however:
    Ebay auction: 370295595931
    It looks familiar and they are stating 24V, 1 amp.
    can I simply use any servo driver on these or do I need specific specs before getting a driver?
    Don't know much about DC servo controllers.
    Oct 2005
    oops
    Dec 2003
    I have seen this size on Burny retrofits and others for converting small trace cutting plasma tables.
    They operate on a rack and pinion with a small fairly high ratio gearbox, this way the torque is amplified considerably and the rapid is plenty due to the fairly high motor rpm and the relatively high distance/rev of a rack spur gear.
    Registered Iron-Man's Avatar
    Jan 2009
    Servo Motors
    These look a lot like the universal magnetics servo motors that I purchased on ebay. I could not find any information about them. I changed out the encoders to HP 500 count. All that I can tell you is that they are very powerful. I was told that they are similar to an electrocraft E543 motor.
    Here is the text from the ebay site"4 new Univeral Magnetics DC servo motors with optical encoders. #'s on label read 84735-01A and 2345113013. We test ran these on our bench supply since no other info was available, and what a surprise...about 3500 rpm at 60 volts and could not stop the shaft while wearing welding gloves (actually melted the edge of the plastic pully). Draw was 2.3 amps, and would guess these are comparable to the Electro Craft E543 that we have listed at this time. A local cnc hobbyist came by last week to buy 4 as he said the specs he found on the net were very impressive, but check for yourself.
    Body with encoder is 5.25"l x 2.25" dia with a .5"
    long .25"dia shaft with a press on pully."
    Hope this helps,
    Iron-Man
    Attached Thumbnails Attached Thumbnails Help: 5 Servo motors.. can't find details??!!-modification_univ_mag_servo_motors_6801_3.jpg   Help: 5 Servo motors.. can't find details??!!-servo_motors_new_encoders.jpg
    Jun 2009
    Quote Originally Posted by Iron-Man View Post
    Hope this helps,
    Iron-Man
    Yup That does help a lot. Is looking better and better.
    I think I may just sell these on eBay as these are over my head at the moment. I have no Servo test equipment.
    Is there a simple way to test these without an encoder? These are Universal Magnetic servos and the size sounds right on.
    Would anyone like to buy one really cheap and test it for me???
    Jun 2009
    Where did you buy your encoders? I would like to grab a few and see what these are like.
    Jan 2009
    Encoders
    I found them one late night while searching on ebay.
    You can see some of my work here;dsPic-Servo
    Iron-Man
    Jun 2009
    @Iron.. Read through the post. Very nice.
    What specs are you seeing with the servos you have and those encoders?
    I'm stuck now. I think I should keep these for my build down the line. I built a PicStep system, just hard to start again right now. A new baby should be here any day!
    Q: Did you use the standard DSPic board on these servos or just the custom config you created? I wonder how the standard (original) would run these.
    thanks
    Jan 2009
    Servo Motors
    JohnnyVegas
    Congrats on the new baby!!
    I would keep the motors, just update the encoders. To answer your question, I built the original design by Mr. Glaister for testing and software modification. The original board works great. Check here; http://members.shaw.ca/swstuff/dspic-servo.html and http://members.shaw.ca/swstuff/
    Watch the video link for this servo amp.
    Download all of the files. There is also a design for a BOB, which I am using.
    I am modifying a pre-cnc Sherline mill and lathe. I plan on using the Litton Clifton Motors for this project. I want to use the universal magnetiics motors for an X3 type of mill. These motors with a 3:1 reduction are way over kill for a Sherline. I am not sure, but I think that the peak torque on these motors, is around 360-400 oz-in. At 3:1 ratio 1200 oz-in is extreme over kill for a Sherline. I am also working on driving AC and brushless servo motors.
    In addition check out Max-Mod's info. Max has done great work with this project and has his own design and software modifications.
    Iron-Man
    Jun 2009
    Thanks again. I listed 3 on eBay today. I'm keeping a few for myself and will build the DsPic soon.
    Ebay Auction: http://cgi.ebay.com/ws/eBayISAPI.dll...STRK:MESELX:IT
    1. Just IN- Provide controllers,drives,servo motors,stepper motors,electronic parts from China
      By Ling in forum Product and Manufacturer Announcements
      Last Post: 07-12-2009, 05:10 AM
    2. Replies: 0
      Last Post: 06-01-2009, 03:26 PM
    3. Help me find the specifications for thes motors
      By le fou in forum Stepper Motors and Drives
      Last Post: 06-08-2007, 07:30 PM
    4. where to find specs for vexta motors
      By DanOSB in forum Stepper Motors and Drives
      Last Post: 09-13-2005, 10:17 PM
    5. Help to find controller card & step motors...
      By Mikael in forum CNC Wire Foam Cutter Machines
      Last Post: 09-11-2004, 06:05 PM
