Old 02-06-2010, 08:52 AM
js412000 is on a distinguished road
soldering ms connector
I am getting ready to solder up my fanuc servo motor encoders with dms3106a20-s9sw connectors.
Do I need to take the individual pins out of the connector to solder them?
I am concerned about heat damaging the blue plastic insulator.
I popped the snap ring out of one unit, and it came right apart, but- with 17 pins each it is going to be a lot of work!
Old 02-06-2010, 09:55 AM
Al_The_Man's Avatar
Thats the hard way.
It is usually no problem soldering in place.
One tip, start at the 'bottom centre' first, othewise starting at the A position blocks succeeding pins.
I usually slip a short piece of heat shrink on first that will cover the pin afterward.
Old 02-06-2010, 11:23 AM
thanks for the help. I will have to pick up some more heat shrink tubing.
[IMG] code is Off
A Primer on Soldering kreutz General Electronics Discussion 0 03-17-2008 07:00 PM
CNC Soldering ChristianW DIY-CNC Router Table Machines 1 06-21-2007 09:16 AM
PCB soldering JamesJmcGEE Welding, Brazing, Soldering, Sealing 22 10-09-2006 06:32 PM
New to silver soldering Flane Welding, Brazing, Soldering, Sealing 8 08-17-2005 07:38 PM
PCB soldering itsme General Electronics Discussion 3 02-16-2005 10:44 AM
