Old 02-04-2010, 09:27 PM
CalG is on a distinguished road
Matching resolver to controller
If a Servo motor with resolver (Moog 303) is spec'd
"3400hz,4Vrms, with a .5 transformer ratio",
and a possible controller (Parker MPA) resolver connection is spec'd
"2000Hz, 20-25 V Peak to peak , Sin/ Cos 0-5VRMS max".
Note: Data from "available literature"
Is there a way ?
I'm thinking the MPA is telling me it wants a 4:1 transformer ratio, or some reduction of applied voltage if wired into a 2:1 xformer.
I may be missing the entire requirement, or at least the "conversion factors;-)
TIA
CalG
[IMG] code is Off
How critical is resolver frequency matching? cra1g3r Servo Motors and Drives 0 01-18-2010 08:22 PM
Need Help!- Matching steppers to drive Grandad CNC Wood Router Project Log 8 10-26-2009 03:46 AM
MasterCAM H&T matching Cory Mastercam 9 04-20-2008 05:35 PM
Matching the electronics Parameter General Electronics Discussion 6 07-15-2005 11:45 AM
motor mixing and matching... charleyy DIY-CNC Router Table Machines 8 09-05-2004 11:32 PM
