Old 02-01-2010, 10:57 AM
Tristar500's Avatar
Tristar500 is on a distinguished road
Mitsubishi AC servo encoder outputs?
I've got a small Mitsubishi AC servo motor model HC-KF43L-S1
Google search points to it being using in commercial industrial sewing equipment. It's got the standard 3 phase + ground for the motor and 9 wires coming off the encoder.
Wondering if anybody can give me a clue as to what wire is what?
Encoder has the numbers OBA17-052 and GAZ63 A A
Any help appreciated!
Is a sentance fragment?
Old 02-01-2010, 12:57 PM
Iron-Man's Avatar
Iron-Man is on a distinguished road
AC Servo Motor
Try this link, see page 56.
http://164.54.212.3/control_systems_..._NA_3181-F.pdf
I hope this helps.
Iron-Man
Old 02-03-2010, 03:55 AM
Tristar500's Avatar
Sweet!, Thanks for the help Iron Man!
I'll give it a try later today.
TS500
Old 02-04-2010, 06:16 PM
Tristar500's Avatar
no luck so far and today called Mitsubishi tech support. They refused to help and told me the motor was only sold with the matching drive and wouldn't give me any other info.
Kinda makes me want to steer clear of Mitsu products.
Old 02-04-2010, 07:03 PM
ee_t is on a distinguished road
Are the wires color coded, or is the circuit board visible?
If its a standard encoder you would be looking at: +5V, Gnd, A, -A, B, -B, I, -I, and maybe a shield/chassis.
edit:
http://china.eb80.com/SaleShow_257531/
http://www.xinyinhui.com/10/75.jpg
Old 02-05-2010, 11:56 AM
Tristar500's Avatar
That's it! those are exactly my encoders.
wires are colour coded.
yellow on pin 1 labled MR
Blu on pin 2 labled MRR
Org on pin 3 labled BAT
Gray on pin 4 labled MD
Wt on pin 5 labled MDR
Purp on pin 6
Red on Pin 7 labled P5
Blk on Pin 8 labled LG
Brn on Pin 9 labled SHD
Any help available on wiring? I can't read chinese.
edit:
Old 02-05-2010, 01:07 PM
Al_The_Man's Avatar
If you are looking to use the motor on some other system you may be out of luck, Mitsubishi use a serial communication system, the MD/MDR and MR/MRR are the two channels.
BT or BAT is to allow for battery retention, LG is logic ground, P5 is +5v, and shield.
Old 02-10-2010, 04:19 AM
battwell is on a distinguished road
the s1 points it as a special
some specials i have here have 1 million pulses per revolution! no good for normal use. eg ose105 used on mitsubishi
like al says they are serial encoders not normal a+ a- etc.
however matched with the correct drive they are fantastic. you just have to watch what you buy.
so much to learn, so much to pass on.
Old 03-06-2010, 11:34 AM
kolokithas's Avatar
kolokithas is on a distinguished road
Mitsubishi servo drive MR-E-70A
Greetings i have a MR-E-70A servo drive from Mitsubishi and i can't find a matching motor for it because indeed Mitsu uses serial encoders for feedback.
I also have an absolute 16bit serial encoder from Yaskawa 2048PPR
Does any one interfaced a serial encoder from another brand with a Mitsubishi
drive?Is there any chance that there might be any compatibility with the pulse trains?
My intention is to use the Yaskawa encoder with the Mitsubishi drive and a Yaskawa motor...
Any suggestions?
thanks
Old 03-06-2010, 01:31 PM
no yaskawa wont work with mitsubishi.
the yaskawa isnt a serial encoder. (and its way too low resolution compared to mitsubishi )
the mitsubishi drives check the parameters (motor type, size, inertia etc) programed into encoder via serial . if not correct will show encoder alarm.
but yaskawa drives are cheap on ebay
  #11   Ban this user!
Old 03-07-2010, 11:39 AM
kolokithas's Avatar
Hi Battwell!
Thought so...
I will probably try to find a servo/drive set than fooling around with compatibilities...
Thanks anyway!
  #12   Ban this user!
Old 04-13-2012, 09:16 AM
volga63 is on a distinguished road
Any suggestions?
thanks
Whether your intention the successful to use the encoder Yaskawa with the Mitsubishi Drive and a Yaskawa motor?
thanks
[IMG] code is Off
Need Help!- Wiring for Mitsubishi AC Servo HA-FF Encoder kumphanart Servo Motors and Drives 5 08-24-2008 01:30 PM
mitsubishi encoder conection rosli Servo Motors and Drives 1 10-17-2006 06:48 PM
mitsubishi mrh servo rosli Servo Motors and Drives 1 07-19-2006 02:49 PM
mitsubishi encoder rosli General Electronics Discussion 2 01-29-2006 06:13 PM
R20x0 encoder outputs? mecheng10 Servo Drives 0 10-05-2005 09:11 PM
