Old 04-12-2005, 05:10 PM
TommyB is on a distinguished road
Rated BLAC servo RPM
I have a new baldor brushless ac servo, bsm80b, and the rated max rpm on it is 4000. I want to use it as a spindle motor and was wondering if these motors can be driven past their rated rpm and how far. I am looking to reach 6000 if it is safe for the motor. Any suggestions??
Old 04-16-2005, 01:02 PM
unterhaus is on a distinguished road
Given a blank sheet of paper, you probably can drive it past its rated rpm. Since you need a driver to commutate the motor, you probably will not be able to do it. The other thing you need is more voltage than it's rated for because just like a brushed pm motor, the speed depends on voltage
[IMG] code is Off
Small servo systems and power supply imserv Product Announcements & Manufacturer News 4 04-03-2008 11:11 AM
Motor calculations jevs General Electronics Discussion 25 03-21-2005 01:05 PM
Help evaluating this servo motor WoodSnarfer Servo Motors and Drives 12 02-05-2005 02:51 PM
What is high speed machining johnm Hard and High Speed Machining 22 12-29-2004 04:41 AM
Brushed servo drive replacement motordude General Electronics Discussion 3 07-06-2004 01:09 PM
