Old 01-28-2010, 02:31 AM
peterson76 is on a distinguished road
Mating servo's to drives
Hello,
I have played with small servos for a long time for different tasks. I usually use my own home made drivers for control.
Now I am getting interested in playing with larger servos. Is there a "cheat sheet" of sorts or a handy way to know what drive works with what servos?
I am refering to Fanuc, there seems to be thousands of servo and drive models from Fanuc. Maybe I'm wrong, but it seems like I could spend weeks researching what drive works with what servo.
Example; I have a servo type: A06B-0315-B206/7073 How do I even begin to find a drive? Its a bit overwhelming.
Thanks in advance,
Eric
Old 01-28-2010, 10:01 AM
Al_The_Man's Avatar
If you do mate them up, then you can run into a problem of integrating the command method etc.
I usually end up converting the proprietary encoder commutation method with a Renco encoder and using a A-M-C servo drive.
There are quite a few previous thread on the topic.
[IMG] code is Off
Newb ? - CAD Part interference & mating part dims pabmartin Mechanical Calculations/Engineering Design 3 11-06-2009 12:18 AM
Need Help!- threading mating parts using caps forhire Mori lathes 3 07-24-2009 01:52 AM
"best" method for fixing together mating tubes? RoGuE_StreaK Mechanical Calculations/Engineering Design 11 06-29-2008 06:20 AM
Mating, how to? dneisler Solidworks 6 12-27-2007 07:34 AM
