Old 01-16-2010, 07:08 AM
gvb gvb is offline
gvb is on a distinguished road
hy-ta4dv
I have a problem with my hy-ta4dv when testing my motors by using the jog panel on (Mach 3) the motors do not work and the leds on the board only glow dull, when the pc is off and there is power to the board all four axis led glow bright and the motors lock up . I am a new comer to cnc
Old 10-22-2010, 08:42 AM
E-Seb is on a distinguished road
i have too this card and i have many problems with manual command and limit switch...
have you a schema with connection for the db15 for manual command
and for the db9 for limit switch?
thanks you for your help
E-SeB
[IMG] code is Off
