| Servo Motors and Drives Discuss servo motors, drivers and other related topics here. |
Early 90's VMC with 0M control......considering a retrofit to MACH 3.... Motor Questions Fanuc Red Cap SPINDLE motor Motor numbers: 8P A06B-0725-B102#3000 200Volt 5.5KW 4 Pole 3Phase 6000RPM Spindle Drive is A06B-6059-H206 .....CAN THIS MOTOR BE RUN WITH A 'typical' VFD? Maybe with a quadrature encoder fitted to the spindle instead of the 'special' Fanuc encoder? There is no transformer, and it appears the drive input is 230V 3Phase even though the motor says 200V ??? Red Cap AXIS motors: X&Y 5S A06B-0314-B002#7000 Z 10S A06B-0315-B002#7000 3 Phase 8 pole 12NM 7.6A stall ....CAN THESE MOTORS BE RUN WITH 'typical' smart AC Brushless drives that take step & direction commands? I realize quadrature encoders need to be fitted to them, but do I also need Hall sensors? The drives I am looking at are Yaskawa or TECO. Thanks. dan K |
| The spindle motor should be able to run on a VFD, if you want close to the original control you need to fit an encoder on the motor shaft. I have previous posts on converting the servo's to DCBL, Renco have encoders that can be used 35i series, you need /4 commutation types (8 pole). Fanuc is all 200vac due to 200v used in Japan. Al.
| Thanks for the reply Al, The spindle has an encoder on it, and I have a Baldor 10HP drive that takes encoder feedback, so that is what I am thinking of using. As far as I can see, there is no transformer in the machine to take the 230v to 200v....? Does the Fanuc Spindle drive do this? Will the Fanuc spindle drive accept +\-10V analog input signals? If so, I guess I could use it and not replace it. On the axis motors, I am not clear what you mean on the encoders...../4 commutation types....? Do you mean quadrature? Can you point me to your posts on converting the red caps? I searched but found nothing. Thanks! dk |
| Here is one such link from post #8 on http://www.cnczone.com/forums/showth...ght=star+point Some Fanuc spindle drives are ±10vdc you would have to check this. The R35i Renco encoders are available from 100 to 10000 p/rev. The /4 indicates pole pairs, IOW for a 1000p/rev 8 pole motor the designation would be 1000/4, four electrical commutation cycles per mechanical revolution. I used a machined shoulder bolt available from Misumi USA in place of the original allen screw that secures the Fanuc encoder, a circular mounting plate has to be fitted to mount the encoder to. The Renco are through hole encoders, hence the need for a machined extension bolt. Al.
| Fanuc 5T Lathe retrofit | NC Cams | Fanuc | 3 | 03-19-2010 03:10 PM |
| Fanuc OM retrofit | dbcoop11 | Fanuc | 0 | 11-08-2006 09:34 PM |
| BP series 1 Boss 4 to EMC Gecko drive Power Supply retrofit | arriflex | Bridgeport and Hardinge Mills | 3 | 10-06-2006 12:43 PM |
| Retrofit of Mill with programable DRO and power feeds | Paraprop | General Metal Working Machines | 3 | 01-31-2005 12:57 PM |
| Choosing a Power Supply for Retrofit? | pfeist | General Metal Working Machines | 4 | 05-23-2004 10:36 PM |
