Old 01-08-2010, 04:42 AM
rai rai is offline
rai is on a distinguished road
servo drive position control by analog 0-10Vdc or 4-20Ma
I am looking for a servo drive to control a position of valve or cam (0 to 270 deg. movement) by analog command 0-10Vdc or 4-20ma. kindly suggest me a suitable and low cost servo drive.
Old 01-08-2010, 09:11 AM
Al_The_Man's Avatar
I have used A-M-C products, also I made up a solenoid controller for a hydraulic servo valve from a single IC that worked well, +-10vdc, National LM759 with a few resistors and caps.
What are you using for the 0-10v command?
Old 01-08-2010, 11:13 PM
rai rai is offline
Thank you very much for your reply. Actually I want to make a fully servo controlled position control valve using servo motor, earlier I was using electro pneumatic position control valve like ABB, siemens make controlled by analog 4-20ma from PID controller, as pneumatic devices are very senstive to mositure, it gets damage very soon. could send me the details of your solenoid controller that you made? it might be useful for my application.
Old 01-09-2010, 10:11 AM
Al_The_Man's Avatar
This is the link, see p10 for the DC motor control, I fed the analogue out from a motion card and used an encoder back to the card for control, it worked well with a hyd servo valve.
http://www.national.com/ds/LM/LM759.pdf
[IMG] code is Off
PWM and DIR -> +/-10VDC analog signal visky General Electronics Discussion 1 11-21-2007 02:28 PM
How to drive Analog Servo Input +/- 10V gurvy General Electronics Discussion 1 05-30-2007 11:31 PM
want to built servo drive(analog and digital) grebator Servo Motors and Drives 0 04-03-2007 10:29 AM
Reconfiguring Yaskawa Drive for Position Control? rpseguin Servo Motors and Drives 13 10-31-2006 07:09 PM
connecting 4-20mA device to analog input Karl_T CamSoft Products 2 09-02-2006 12:52 PM
