Old 01-03-2010, 07:50 AM
ElectroMachine is on a distinguished road
URGENT - Gould Gettys N360 Three Phase Half Wave Controller
Dear Sir,
We need to buy Gould Gettys - N360 Three Phase Half Wave Controller ( SCR )
Type : A121
Version : A121-39135-C-04
240-300 VAC Line to Line 50/60 Hz
Rated Motor Current : 33 A
45A D.C. Continous Max.
Qty --- 1 pc.
Please advise the availability / Lead Time & price.
If the above item is not available / or discontinued, please advise a suitable 1:1 replacement of the above.
MATTER MOST URGENT
Old 01-03-2010, 09:34 AM
Al_The_Man's Avatar
You may have a problem getting an exact replacement as Getty's no longer exists.
The options are repair to the existing one or sub a replacement from Baldor.
Another is to retrofit with a AC spindle from Mitsubishi etc.
The AC retrofit is often the same price as 3 phase DC replacement.
Obviously the Baldor or Mits replacement requires some degree of knowledge capable of integrating the new unit.
Old 01-03-2010, 09:48 AM
Hi Al,
Thanks a lot for your feedback.
Can you advise a suitable part number / Type number of Baldor / Mits that can be used in place of this gettys unit?
Best Regards
EM
Old 01-03-2010, 10:14 AM
Al_The_Man's Avatar
I do not have specific part numbers for your application and the Baldor part numbers I have are dated.
I would suggest contacting both Baldor and Mitsubishi for direct quote.
The older info I have for Baldor is the BC20H series.
The current Mitsubishi drives are SPA series with compatible motor supplied.
You need to know the actual line to line voltage.
The Mits will required both elecrical and mechanical changes, but if the motor is older or you anticipate motor problems down the road, the AC is the better way to go, especially if you are looking to keep the machine for some time.
Old 02-05-2010, 11:26 AM
junkyardfairy is on a distinguished road
I have the item. Call me at 310-951-0105 or email me at junkyardfairy@yahoo.com. I can respond in the evening Pacific time.
[IMG] code is Off
Need Help!- Gettys Gould DC servo motor catalog SHIVAMN Machine Problems, Solutions , Wireless DNC, serial port 0 07-24-2009 03:11 AM
Need Help!- Gould Gettys 410 Serial Coms BMTS Machine Problems, Solutions , Wireless DNC, serial port 0 03-28-2009 05:22 AM
Sine wave for 5 phase 10 wire stepper (non-stared) terrym LinuxCNC (formerly EMC2) 2 09-29-2008 04:57 AM
Gettys N360 three phase half wave bsharp Servo Motors and Drives 7 08-05-2007 09:06 PM
gould gettys servo motors kollander Servo Motors and Drives 5 12-25-2006 12:14 PM
