Old 12-26-2009, 08:38 PM
CarbonDave is on a distinguished road
Maximum Voltage
Hello, I I have just acquired a Wells-Index CNC. It is old but mechanically in fantastic shape. You can look at pictures here. http://picasaweb.google.com/CarbonDa...sIndexCNCMill#
One question I am having is about the motors. I have found that they are these ( http://www.elwood.com/m100_data4a.pdf ) The m112 models. The name plate has no info on the maximum voltage that these motors can run. The transformer for the power supply was tapped at 65vac so I am guessing they were set up for somewhere around 85vdc.
Any help would be greatly appreciated. I am sure I will have a ton more questions but at least this will get me started on which controllers to use and such.
Old 12-26-2009, 10:55 PM
Al_The_Man's Avatar
They apparently are rated at BEMF of 34.8v/1krev, and ~2400rpm so the max voltage will be around 84vdc for max rpm, the supply would normally be higher than this value by at least 10%.
Old 12-26-2009, 11:41 PM
Al, Thanks for the response!! That will give a good idea of what drives I can and can't use.
Next thing to figure out is what type of encoder it has. I know it is a Datametrics-Dresser but have been unable to find any info on them. I don't have the part number with me at the moment. I do recall something about LC23.
Here is a picture of the encoder. At least I think it is an encoder.
http://lh3.ggpht.com/_4Qj6pwtP9CU/Sz...0/IMG_5262.JPG
http://lh5.ggpht.com/_4Qj6pwtP9CU/Sz...0/IMG_5258.JPG
[IMG] code is Off
Need Help!- MAXIMUM CUT OFF CNC_BOB Okuma 4 10-29-2009 02:32 PM
Help..Stuck at relay ext dc voltage missing but dc voltage OK ? Dirky Bridgeport and Hardinge Mills 24 11-27-2007 07:33 AM
Maximum speed fbazan Yeager Automation 0 09-13-2006 09:30 PM
Servo maximum voltage bgolash Servo Motors and Drives 1 04-11-2006 07:45 PM
Maximum Voltage for L298 IC ? gcamlibel General Electronics Discussion 27 05-14-2004 12:36 PM
