| Servo Motors and Drives Discuss servo motors, drivers and other related topics here. |
Hi, I am amasing parts for my first CNC router table. I have managed to lay my hands on a fantastic unit that is a motorized lead screw mounted to a linear slide giving about 5" of travel It's from the 80's and has a 20 turn potentiometer mounted to an integral rack and pinion system. So the pot provides feedback. This is earmarked for my z axis drive.. It wouldnt be difficult to swap the geared DC motor with a servo but I just wanted to ask if it'd be feasible to use this as it somehow or will I need to use a stepper motor? |
| High quality DC servo's are constructed slightly different from ordinary DC motors, but it may be possible to add an encoder and use it as a servo, if it was used for precise positioning before, there is a chance it may have the potential for a servo axis. Al.
Yeah this is from a piece of medical equipment, I had a closer look and its a maxon gearhead dc motor but there are 4 wires coming out the end of it.. I need to investigate further. It doesnt look like a servo , it might have built in encoder.. thanks for the info anyway.. |
| I would guess 2 wires are for the motor and two are for a thermal switch, could be wrong though. If there are only 4 wires, it does not have an internal encoder. You might also consider the amount of backlash in the gearhead, whether it is acceptable or not. Matt |
| Hello, I have ametek motors that I bought from surplus, do you think that this motor is dc servo motor or its just dc motor. The motors, some have 2 shaft, long (1.5 inch) in front and short (.25" in) in the back. I also have bought CUI encoder for this motor. Do you recommend to use this motor with this encoder? What about performance based on your experience will be? Thanks. |
| Sure, it can be done. There are some cogging issues that will impact performance relative to purpose-built servos, but you can make a servo out of a DC motor. Here is a good resource: http://www.truetex.com/servomod.htm Best, BW
__________________ Try G-Wizard Machinist's Calculator for free: http://www.cnccookbook.com/CCGWizard.html |
The tach is usually the rear most mounted. If it has a tach, it is an indication it is servo grade. Al.
Hi All, Yes the unit on the end is a DC-Tach. The gearhead is 5:1 and at 12v the unit travels the 5 or so inches in about 10 seconds. The lead screw is a high quality system.. so I think I've picked up a real piece of good luck here. The tach might have to swap for an encoder.. Thanks for the link Bob, that info is perfect. |
| Need Help!- wondering about Keling servo feedback cables? | aaronwelder | Automation Technology Products | 0 | 10-24-2009 09:00 PM |
| Which servo drive can handle AC motor without Hall feedback? | scsi | Servo Motors and Drives | 4 | 10-08-2009 01:37 AM |
| Need Help with acquiring new servo feedback cable | fabshop | General Metal Working Machines | 3 | 09-25-2009 07:39 PM |
| Okuma VAC-Motor feedback control? | DennisCNC | Servo Motors and Drives | 1 | 10-03-2006 10:08 PM |
| stepper motor feedback question | Syp | Stepper Motors and Drives | 5 | 02-06-2006 11:36 AM |
