Old 12-07-2009, 04:29 PM
clintan99 is on a distinguished road
Smile Retrofit MORI-SEIKI SL1-A
Hi guys!
I have a FANUC AC-SPINDLE DRIVE A20B-1000-0692 and want to connect it
to a FAGOR 8055 TC i need help with the analog i/o betwen the drive and
8055
Old 12-11-2009, 02:09 PM
Fagor - Todd is on a distinguished road
Originally Posted by clintan99 View Post
Hi guys!
8055
As far as hooking up the analog command to the spindle drive, its a simple thing. You can find the pin-outs from the 8055 in the installation manual. You also have an enable signal and possibly the spindle drive requires and M04 and M05 direction command, both of which the CNC can easily supply via the I/O.....
Tell me more about what the Fanuc drive requires and I can help you determine where and how to hook up from the Fagor CNC perspective.
Old 12-11-2009, 03:56 PM
Exclamation
thanks Fagor-Todd
i dont have wiring diagram on the spindle drive an than idont sure how i
connect it, the CN2 connector on the spindle drive is the problem.
Fagor 8055 i have all installation manual thats no problem, do i realy need to
connect the signal in rrc-1 on the FANUC AC-SPINDLE DRIVE A20B-1000-0692 ????
rrc-1=spindle forward,spindle reverse,spindle orient,spindle auto,spindle manual, i wont 8055 to do that instead if it is possible
[IMG] code is Off
Problem- Did Mori Seiki Buy Hitachi Seiki? Billet Sean Mori lathes 6 05-04-2011 10:12 PM
Mori Seiki Sv-503 mr-seiki Servo Motors and Drives 2 06-03-2010 08:52 PM
mori-seiki ron2008 Mori Mills 2 10-08-2008 03:22 PM
Help Required - Mori Seiki TL 2 (RETROFIT) maxman General Metal Working Machines 6 04-08-2007 09:22 AM
