Old 12-02-2009, 08:48 AM
Jeshua is on a distinguished road
Lightbulb Differential for Encoders?
Greetings,
I have to have two of my servos connected to my Gecko 320s with more than 6 feet of cable (I guess I will need around 12 feet).
Do you think it might work without differential signals?
The two servos in question have a US Digital encoder (HEDS-9100-A00).
I assume I would need something that connects to the US digital encoder that converts the signal to differential, then another device that connects to the Gecko 320 that converts the differential signal back into what the Gecko expects.
Can anyone recommend a source for reasonably cost signal differentials?
Thank you!
Old 12-02-2009, 09:40 AM
BobWarfield's Avatar
BobWarfield is on a distinguished road
Sure it can work. I run more than 6 feet. You need to do a couple of things to maximize you chances.
First, run shielded cable and ground the cable at you electronics enclosure end rather than at the machine.
Second, since you're running HEDS encoders, be sure to add the bypass capacitors Mariss F. has recommended.
I'm not having any problems since having done those two things.
For more on the bypass caps for HEDS, go to this page:
http://www.cnccookbook.com/CCMillCNCHome.html
and search for HEDS.
Cheers,
BW
Try G-Wizard Machinist's Calculator for free:
http://www.cnccookbook.com/CCGWizard.html
Old 12-02-2009, 11:00 AM
keebler303 is on a distinguished road
Its probably worth trying first without the differential signals.
If you have problems, US Digital sells differential drivers/receivers to convert your encoder to differential signals. I don't know if you would consider it a resonable cost or not.
If you are moderately electronically inclined, you can easily fabricate them yourself and save some money by using 26ls31 and 26ls32 chips. They can be had from digikey or elsewhere for a buck or less.
Matt
[IMG] code is Off
Wiring differential encoder scrambled Granite Devices 25 09-06-2009 01:56 PM
Differential Encoder Signals eloid DIY-CNC Router Table Machines 8 01-29-2008 08:05 PM
differential encoders with Gecko G320 jed102 Gecko Drives 4 10-02-2006 04:37 PM
Differential threads... Chuck Pressure General Metalwork Discussion 7 09-24-2005 11:01 AM
Synchro Differential Gen ?? Wannabe General Electronics Discussion 3 03-23-2004 06:36 PM
