Old 03-26-2005, 03:15 PM
wotje is on a distinguished road
Techical specification Electrocraft 0643-08-013 ?
Hello,
Is there anybody who can give me techhnical information about a DC motor from Electrocraft.
I did purchase them on a fleamarket.
I did a search on the internet but there is not much information avalable.
I do have 2 motors., model no. L19-2 and one E19-2.
The difference is how the shaft is made. Farther are they both the same.
Part number : 0643-08-013.
And both motors do have a electrical brake on it.
The length of the motors without shaft and the brake is 140 mm or 5 and a half inch.
And the with is 83 mm or 3 and a qurter inch.
If somebody could tell me the maximal voltage and the nominal current. I would already be happy.
If there is somebody who nows the rest of the specifications. Then it is in words impossible to tell you how I feel me. ;<)
Old 03-26-2005, 03:31 PM
Al_The_Man's Avatar
I have the catalogue specs on 0643-31-011 & 0643-32-011 models, these were the 0643 off-the-shelf models and I believe the other numbers are special order and may have been just different mounts or shaft size etc.
Al
Old 03-26-2005, 05:11 PM
Hello All
Is there a possibility to post them here or couldt you tell me where I can find them?
Old 03-26-2005, 06:16 PM
Al_The_Man's Avatar
I will post them here in case someone has the same question in the future.
Of the two models, one show the specs in oz-in and the other in lb-in, but converted they appear to be close to the same.
0643-33-004
continuous stall 155 oz-in
pk torque 720 oz-in
max terminal voltage 60
max speed 4800 rpm
inertia .0304 oz-in-sec^
Kt 16.8 oz-in/amp
Ke 12.4 v/krpm
max pulse current 43 amp
Inductance .5mH
0643-32-004
continuous stall 9.7 lb-in
pk torque 45 lb-in
max speed 3700 rpm
inertia .0019 lb-in-sec^
Kt 1.34 lb-in/amp
Ke 15.9 v/krpm
max pulse current 33 amp
Inductance .8mH
Good luck
Al
Old 03-27-2005, 05:33 AM
Thank you verry much.
Old 09-11-2011, 08:18 AM
Vejrhansen.DK is on a distinguished road
Exclamation
0643-33-004
pk torque 720 oz-in
max speed 4800 rpm
Kt 16.8 oz-in/amp
Ke 12.4 v/krpm
Inductance .5mH
0643-32-004
pk torque 45 lb-in
max speed 3700 rpm
Kt 1.34 lb-in/amp
Ke 15.9 v/krpm
Inductance .8mH
Good luck
Al
________________________________________________________
Hi
How nice, I have one, almost the same identical to the name, model E19.
It would help me a lot if I could get some help to identify this model.
permanent Magnet
Servo Motor Tach
PartNr: E644-61-001 (E is maby a 5 )
Serial No: H 00537
Date Code: 254
Regards J J Hansen, Denmark
It could be a good stable engine on my cnc. I think.
Vejrhansen / cnc / cnc.htm
merkur23 (@) mail.dk
Old 09-11-2011, 09:29 AM
Al_The_Man's Avatar
Check your email.
[IMG] code is Off
