Old 11-25-2009, 10:07 PM
draughted's Avatar
draughted is on a distinguished road
servo advice please
hi i am just a little curious at the moment about the fact servos do not lose steps with a computer with bad latency, but i am told do not go to the same resolution as a stepper.
so could anyone tell me the basic types of servo, new and old
and wether my G540 is worth replacing, given it suits my power requirements.
do they suffer interference the same as steppers. i'm under the belief many of my stuffups are caused by bad electrical interference
generally i'm looking to get the best system i can afford.
Old 11-26-2009, 12:29 AM
H.O H.O is offline
H.O is on a distinguished road
A badly designed and implemented servo-system will work just as bad (or worse) than a badly designed and implemented stepmotor system. Saying that a servomotor can't lose steps is only partly correct.
If you overdrive a stepmotor it will lose steps and/or stall out, if you overdrive a servomotor it "fall behind" the target position until it's so far off that the drive (or controller) will fault, how far this is is usually setable.
That doesn't mean a servosystem is immune in any way, if it's implemented badly you might get noise on the encoder signals fooling the drive (or controller) into thinking the motorshaft is in a position where it in reality isn't. The effect is just the same as with the step-motor being overdriven and losing steps - you get inconsistent positioning, ruined parts etc etc.
The resolution you get depends on the line count of the encoder, a 500 line encoder will give you 2000 "steps"/rev, a 4000 line encoder will give you 16000 "steps"/rev.
Old 11-27-2009, 01:12 AM
draughted's Avatar
if thats the case then i'm happy as is.
i suppose the way things are done with steppers is not that different. i was just looking for that bullet proof ideal system that doesn't exist.
all things have there faults, even me.
[IMG] code is Off
Problem- BL -80 SERVO OR REPAIR ADVICE NEEDED NJC Okuma 0 01-06-2009 07:27 PM
Need advice on Brushless AC servo drive panaceabea Servo Motors and Drives 15 04-25-2008 11:34 PM
Servo components advice Chris64 General CNC (Mill and Lathe) Control Software (NC) 44 01-22-2008 12:10 AM
servo advice eloid Servo Motors and Drives 0 11-18-2007 07:21 PM
Need advice on servo controls cncpro General CNC (Mill and Lathe) Control Software (NC) 5 08-13-2005 10:03 AM
