| Servo Motors and Drives Discuss servo motors, drivers and other related topics here. |
This may be a simple question but i'll ask anyway. I have a DC servo motor i got from an indexer at work. The encoder circuit has a short in it somewhere that put the machine in a fault state all the time. My question is... can i use the servo as a normal DC motor? or does it require a controller like a stepper? My goal is to use the motor simply as a "turn on turn off" motor in a homemade Drill press, as i think it will have the nessasary torque, but won't require the use of the encoder. Thanks Kevin |
| Yes, but it will depend on the type of controller you have, or intend using, does the motor have a tach? If the ampifier allows the use of velocity mode, you can but you may find that without a tach feedback the speed will vary somewhat under load. Al
| So it will require some sort of controller? If so i may be better off getting a DC motor for my drill press app and saving the servo for a use where its abilities would have a point. I'd just need to replace the encoder. As for does it have a tach.. I really don't know. Guess i need to do more HW on the servo itself.. |
Al
| I was planning on useing a belt driven pully system to the shaft with different sized pullys similar to the Drill Presses at work for change the speeds. basically i just want to be able to use the motor as a motor at a constant speed with the best use of the servo's torque. I was using a simple stepper motor with a little homemade controler that just spit steps at it to make it spin, but the stepper doesn't have much torque. Basically i just want to turn the servo into a normal DC motor. Apply voltage to get forward movement.. apply reverse voltage to spin it backwards. thanks again. Kevin |
| If it is a good servo motor the speed will be mostly dependent on the voltage you apply. Much more so than a non-servo motor. What Al wrote, is true. I just point out that it will be better in this respect than most common DC motors, and probably a good spindle motor. |
| You will need a DC supply suitable for the voltage & current rating of the motor. Plus fusing etc. Al
#10
| You dont need the encoder. You might want to wire a reversing contactor though. Al
#12
| There are a lot of DC motor speed controllers on Ebay. Seems like they don't usually go for that much. http://tinyurl.com/4jk75 If you really get obsessive, drives are scattered all over the business and industrial section. Otherwise you just need an unregulated supply. |
| Using surplus servo motors as spindle drive | Swede | Servo Motors and Drives | 11 | 03-16-2008 08:05 AM |
| Servo Motor Running away. | murphy625 | CamSoft Products | 38 | 02-27-2005 01:08 PM |
| Mixing servo and stepper | ty1295 | Servo Motors and Drives | 0 | 01-19-2005 09:26 AM |
| buzzing servo | harvard5 | Bridgeport and Hardinge Mills | 3 | 08-17-2004 07:42 PM |
| steppers or servo drives | mmjpotter | Gecko Drives | 14 | 03-30-2004 02:56 PM |
