Old 11-16-2009, 08:05 PM
MSGMachine is on a distinguished road
Checking My Servos
I have some older SEM DC brushed servos that I need to make sure they are in good shape before I put them on a new controller and damage it. The controller supplier told me to
Short the windings together. On DC brush servos there are two wires. On AC brushless servos there are three wires.
• There should be a noticeable increase in drag, but you should still be able to spin the shaft with your fingers.
• If there is no additional drag, you may have an open winding or bad magnets.
• If the resistance is not smooth, but has skip spots, the motor is bad.
Just what do they mean by shorting the windings together?
Old 11-16-2009, 09:17 PM
Al_The_Man's Avatar
What they mean is short the armature terminals, when you give the shaft a sharp spin, the generated voltage act as a brake, it is rather a crude test.
You can also check them with an automotive battery for current in both directions.
Old 11-17-2009, 03:50 PM
Just what am I looking for on the ampmeter?
Old 11-21-2009, 07:44 PM
I hooked a D cell battery up to my servos and they ran smooth. I asume that since a D cell cannot supply many amps that this would be a good test for the motors. would you guys agree?
Old 11-21-2009, 11:06 PM
Al_The_Man's Avatar
That is a bit low a voltage and cannot supply much current, off load, once they have reached terminal voltage, the current will be low, value will depend on the motor.
[IMG] code is Off
Looking for NC checking software... Jesusbot General CNC (Mill and Lathe) Control Software (NC) 4 Yesterday 10:36 AM
Newbie- Checking out a hurco Dave Rothermel HURCO 3 07-16-2009 05:33 PM
CHECKING CHANDRU Fanuc 1 12-24-2007 07:48 PM
checking accuracy DEW CNC Plasma and Waterjet Machines 2 10-01-2005 09:27 AM
Newbie checking in. jstuedle DIY-CNC Router Table Machines 10 06-30-2004 10:58 PM
