| Servo Motors and Drives Discuss servo motors, drivers and other related topics here. |
I have a Yaskawa AC, (brushless DC motor), servo drive. The bearings failed after years of service. The the drive was disassembled, bearings replaced, and the drive put back together. This includes pressing the encoder back onto the shaft. Sweet! Everything looks great and feels nice. Power it up and... The shaft turns about one revolution and shuts down. Does this everytime. We stick an identical motor/encoder unit on and it runs fine. I'm getting a feeling that some sort of alighnment is required between the encoder and the motor position so the motor controller knows how to sequence the power to the motor. However no indexing marks were ever noted or made, and there seems to be no easy way to adjust the alighment. Everything gets pressed on and off the shaft. Does this alignment issue ring true to you? Any bench top suggestions or proceedure you know of? |
| You have to detect or find out what feedback/commutation system is used, if it is hall effect simulated pulses on the encoder, I have done it for these kind of systems using a double beam scope. Al.
| Hi Al. To be even reasonably smooth and powerful BLDC motors need position information fed back to their controllers. Normally it's something like a Hall effect switch(s). But I can see that if I were designing a system that had to have an accurate position encoder on it for other reasons, I'd try to use that same encoder to provide my motor position too. So you're agreeing that the encoder does have to be "aligned"? |
| Depends whether the motor is AC sinusoidal or BLDC, often both motors use the same method, except AC sometimes use it momentarily at start up. The modern method of simulating hall effect devices is the pulses are included as separate tracks on the encoder disk. I have outlined the method in previous posts, I can post it again if you need to align using hall type outputs. Al.
| That was very useful! I did not realize that was what those other tracks are. I would greatly appreciate you reposting it, or directing me to where it was last posted. Or just some key words to search with as I searched much on this question before starting this thread. |
| The encoder has to be rotated until Hall A coincides with Phase A. Al.
| Need Help!- Possible bad encoder on X servo | bherr | Bridgeport and Hardinge Mills | 42 | 09-21-2009 03:47 PM |
| Encoder / Servo | stevo1 | Fanuc | 0 | 07-10-2008 01:06 PM |
| Grizzly G3617 Conversion - Timing pulley sizing and servo/stepper questions. | turbostang | Benchtop Machines | 15 | 05-19-2007 04:12 PM |
| servo encoder question | CNC Darren | Servo Motors and Drives | 0 | 03-08-2007 04:20 AM |
| servo encoder placement? | tooManyHobbies | Benchtop Machines | 0 | 12-01-2006 12:46 PM |
